Original OEM GM Distributor question
Old Feb 17, 2009 | 08:40 PM
ED69ray's Avatar
ED69ray
Default Original OEM GM Distributor question
I recently pulled an original OEM tach drive distributor off the NOM L-65 sb engine in my '69 model
It's an OEM piece with an intact metal ID band as pictured.
ID band reads:
1111464 DELCO REMY 0B23
1111464 indicates 1970 454ci/390hp
0B23 indicates 1970 Feb, 23rd
QUESTION: it appears this is a 454ci distributor - can this be correct as this was an operating dist on a small block 350?
Old Feb 17, 2009 | 08:46 PM
midyearvette's Avatar
midyearvette
ID band reads:
small block and big block distributors are interchangeable......probably only the advance curves may be different and possibly the vac. advance....you can have it all set up on a distributor machine to any spec you like...........
Old Feb 17, 2009 | 09:08 PM
ED69ray's Avatar
ED69ray
thanks for the info - already bought a complete MSD setup. Gonna put this up for sale - just wanted to make sure I listed it correctly.
Thanks, Ed
Old Sep 22, 2010 | 01:15 PM
tcramstrek's Avatar
tcramstrek
4th Gear
Default 1111464 Distributor
Hi I am looking for a 1111464 distributor, how much did you sell it for?
To Original OEM GM Distributor question
