Do you think this frame is fixable?
Somebody did the repair and put a front cap from a 1980 on the car, but I noticed a while back that the front drivers wheel is centered in the wheel well and the passenger side is set back a bit.
Passenger side:
Drivers side:
Under the frame on passenger side, you can see the crumple and in the third pic down the repairs where they spliced and welded that side, that made hard to see, but the area had been welded on a bit.
I took it to a guy that retired and put his frame straightener in his back yard shop, and still does business on a part time as a hobby.
He's one of those 67 year old school guys that has a Budweiser in his hand at 8:00 in the morning.
He called me over after looking at it and said he didn't want to work on it, he said it was a mess. I'm kind of on the fence here because he was a little "lit" and slurring his speech, so I feel like because it wasn't an "easy" job and just didn't want to touch it because it wasn't something he could get through quick. He was trying to work on his garden and build another shop building at the same time.
So do you think this is repairable? My only other option is to swap frames, I found one today that the owner wants 700 for, but it had some rust holes in it so it would need to be repaired. Plus it would be a huge pain to swap everything over.
If anyone knows of a really good frame shop in the Jonesboro, AR area please let me know.
look it over closely.. you are right, it might be easier and cheaper to just put a new frame under it
Passenger side:
Drivers side:
What is it you want from this car? Does it ride funny, wear tires, or just the look of the tires in the wheel well? Make sure that the frame is in a safe condition to drive and then check the wheel base from side to side. If the side to side measurement is good then you could just move the body around. The body will move a fair amount on the frame with all the bolts loose.
No matter what you do, the first thing is to take it to a 4-wheel alignment shop and find out how far it is off and what is off. Your ride height might be off, and your tracking might be off. Until you get the print out, you really don't know what else might be wrong. You need to make sure the car is safe to drive.
I don't see anything on the frame that is unrepairable. Most places are cautious, because body damage can be caused by the frame machines. They might pop the nose loose by pulling on the rails. Whoever does it, needs to be an experienced Corvette shop.
You have several options.
1. Get a new frame. This will run between $3,000 and $5,000 by the time you are done. The "while I am at it" cost is WAY more than the initial frame cost. But, when you are done, you will have one super sweet car.
2. Have your frame tweeked. This will run between $500 and $1000 as long as they don't cause any other damage while straightening the frame.
3. Sell the car. This could cost you $5,000 to $30,000 to find what you want to replace it with, and you will probably be without a car during the cruising season.
4. Drive it and don't worry about it. This will cost you nothing. I suggest you do this. If it really bugs you, just turn the wheels when you park the car, and you won't see it and nobody else will notice it either.
The reason your wheels are not lining up the same has to do with something else wrong / bent up front. The frame doesn't look too bad at all to me
My 2 cents
Like mentioned, your body may not be properly squared to the frame. This is easily checked by removing your door sill moldings and pull the carpet back slightly. There should be two orange plugs per side that are inserted into the door sill ledge. Pull them out and look down through them. One hole on each side allows you to insert a dowel the size of the hole you are looking through, and it should fit into the holes in the frame of the same size. When both dowels are inserted THROUGH the frame and standing straight up and down, your body is now centered to the frame as required. But in order to do this many components must be loosened. But it is an easy check, if you can see through down to the ground and the holes are in line, it is not you body to frame alignment. You will know what I am writing the second you see it. GMC "DUB"
A body shop could perform a frame measurement and determine the position of all points of the frame.
You could crawl under the vehicle and visually inspect all the bushing and mount positions of the front end suspension components. If anything really out of whack it should jump out at you. If that was the case though you probably would have noticed handling problems.
So; second opinion??
I dont know how handy you are, because this wont neccessarly be cheap to pay someone to swap out the frame, but you could probably find a good used frame for 6-7 hundred (maybe less if you shop around) and then it would be a non issue. On top of that you could have it powder coated nice and clean and it would go well with the good looking body work. Just a thought.
Just finding a good 80-82 frame in my area is the problem. And if you do they want quite a bit for it.
I would rather go that route and build a good undercarrige to swap over.
