wiper door?
Old Feb 19, 2009 | 01:18 PM
71coupe454's Avatar
71coupe454
Default wiper door?
search aint working? open wiper door? no engine or battery
Old Feb 19, 2009 | 01:42 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
IIRC: remove the rubber dust cover on front of the vacuum actuator, insert a tool (screwdriver) and push. I believe that allows the wiper door to move up and towards front of car, exposing the wiper blades.
Old Feb 19, 2009 | 01:52 PM
BB68Vett's Avatar
BB68Vett
71white's Avatar
71white
I was just about to ask the same question.
Old Feb 19, 2009 | 05:49 PM
Sully1882's Avatar
Sully1882
shouldn't you be able to grab the back of the door, near the windshield, and light up and back? That is if the system is working correctly.
Sully
Old Feb 19, 2009 | 06:02 PM
71coupe454's Avatar
71coupe454
Pushing the rod worked. I was afraid to pull on the door too hard but that might have worked.
Old Feb 20, 2009 | 01:43 PM
71white's Avatar
71white
I took off the wiper door and broke off 3 of the 4 bolts. Be careful, I even used PB Blaster
Old Feb 20, 2009 | 02:40 PM
Alan 71's Avatar
Alan 71
Hi Sully,
I believe if you pull the door with open without taking the plug out of the actuator it's hard on the diaphragm in the actuator.
Regards,
Alan
Old Feb 20, 2009 | 03:44 PM
PeteZO6's Avatar
PeteZO6
That's the way the Owner's Manual sez to do it!
To wiper door?
