Pass side window stuck?
Old Jan 24, 2002 | 10:24 PM
dogboy's Avatar
dogboy
Default Pass side window stuck?
I have power going to window but it dosn't even budge? Sounds like window motor? What do you think. The driver side works well.
Old Jan 24, 2002 | 10:35 PM
PatG's Avatar
PatG
Default Re: Pass side window stuck? (dogboy)
Mine have stopped working before, cleaned contacts on motor and that fixed it.
Old Jan 25, 2002 | 09:55 AM
woodworkr's Avatar
woodworkr
Default Re: Pass side window stuck? (PatG)
If the motor has power and not operating, you could try taking out the motor and cleaning all the goop and dirt that accumulated around the gear shaft in the motor. That old grease can get like cement after years. Clean it all out good and then WD 40 around the shaft and repack with Luberplate. Also as said in another post, clean the contacts. If it still doesnt work after that time for a new motor. If the motor is turning and the window doesnt move, then look to the window regulator gear, that has a tendency to strip out in the area of operation. Also the gear on the motor.
Good Luck
JoeB
Old Jan 25, 2002 | 11:21 AM
dogboy's Avatar
dogboy
Fixed it! Damn thing was stuck somehow. I checked the wires all looked okay and it made a click sound when power was applied. I hit the top side once with the rachet wrench and presto. It seems to be working fine now. Thanks for the help. :smash:
Old Jan 25, 2002 | 11:29 AM
Edzred72's Avatar
Edzred72
Fixed it! I hit the top side once with the rachet wrench and presto. It seems to be working fine
Sound like it's time to clean-em and grease-em up. Bet it will stick again :yesnod: :yesnod:
Old Jan 25, 2002 | 11:49 AM
bence13_33's Avatar
bence13_33
My driver's side power window sticks every once and a while. It seems like there is a "dead spot" on the motor. If I bump the inside door panel ever so gently it starts working again....I can't tell you how many times I've had that door apart.
Old Jan 25, 2002 | 09:37 PM
vettecor's Avatar
vettecor
My passenger side window did the same thing last year and the Corvette Museum. Window was down, (of course), and would not budge. I pushed down on the window a little bit, and the window has worked fine ever since.
Go figure.
Larry
To Pass side window stuck?
