Making the manual crossmember removable
Old Feb 22, 2009 | 01:40 AM
69 Convertible's Avatar
69 Convertible
One of the hard part of this job was to try and cut the crossmember straight. With no lift like some members may have, I did mine laying on my back and not enough room to work. My cut was not too straight despite me trying to make it. I grounded and trimmed it to make it straight and level. In doing so, I had a bigger gap. Also, It had to be cut more because of the 4 1/8 inch plates I used. So you will have to ground or trim it. Also, That's why I said to make sure to take the trans mount bracket measurements so when you weld everything back, you'll have it right where it belong. Not shifted to one side or the other. If I didn't know a welder at work, I don't think I would have done this job. Would had to tow it to a shop or hire a welder to come to my house. At home I had control and worked at my own pace. And it didn't cost me anything. It was scary for me to even consider doing it. But it all worked out for me in the end. As for the ground strap, everything was still being put together. Progress pictures.
Old Feb 22, 2009 | 09:20 AM
69vettester's Avatar
69vettester
I swapped my Muncie for The Richmond Overdrive some years ago, Heres some pics and details. Quite a few have done it this way.
Good luck with it.
http://69vettester.com/richmond.htm
Old Jan 25, 2024 | 06:45 PM
mad4slalom's Avatar
mad4slalom
Default Crossmember cutting
Originally Posted by carriljc
If I were to do it again, I make the cuts further inboard.
As far cutting, just use a sawzall or a circular saw. I used a rope saw to cut mine, but there's no need to be that accurate.
All stitch welds completed and painted this gray that I really like.
Do you have pics of a rope saw that will cut metal and who makes one 👍 thank you
Old Jan 25, 2024 | 07:45 PM
carriljc's Avatar
carriljc
mad4slalom
Wow. Old thread. I bought the rope-saw at Denault's. Nothing special. Hat 2 big handles at either end. I may still have it ...but it would be hell to find! I will look.
I've gone through different changes now.
I modified the removable one to make it such that the exhaust "passes under".
THEN, I removed that thing and made my own out 3" by 3" box steel.
MY recommendation is that if you are going to make it removable just make the exhaust "pass under"....while you're at it. It is a lot better all the way around. Let me find some pics.
Here....you can my crossmember pics and modifications here: https://www.corvetteforum.com/forums...post1607005557
Old Jan 25, 2024 | 10:56 PM
carriljc's Avatar
carriljc
Default well, I'll be dipped in......
mad4slalom
haha.... found the rope saw where I left it about 26 years ago. I looked at my records and I first cut that crossmember in February 1998.
Old Jan 26, 2024 | 01:20 AM
vettebuyer6369's Avatar
vettebuyer6369
The picture is missing because you re answering a post from 15 years ago.
