Bowler Hydraulic Clutch Conversion Kit
Old Apr 19, 2017 | 01:10 PM
SteveG75's Avatar
SteveG75
Default Bowler Hydraulic Clutch Conversion Kit
Has anyone used the Bowler Hydraulic Clutch Conversion Kit?
I am currently running a T56 Magnum behind my BBC with a mechanical clutch linkage. I am considering updating to a hydraulic linkage this winter. Anyway, I found the Bowler kit on the their webpage and it looks interesting since the they mount the master cylinder to the Z-bar mount on the frame vice the firewall which should help reduce flex. It is pricey though.
https://www.bowlertransmissions.com/...c3-clutch-kit/
Old Apr 19, 2017 | 04:32 PM
theandies's Avatar
theandies
$865.00
Old Apr 19, 2017 | 06:00 PM
Richard454's Avatar
Richard454
Ummm...that's a little pricey....
Steve-
I'm thinking you can easily whip up a ½thick chunk of aluminum and make your OWN mount. My Wilwood clutch master was like $100- lines were about $40 and the OEM type constant contact throwout bearing a few hundred. And had a extra motor lift bracket laying around to beef up the fiberglass firewall!!
Plus if you remove the Z-bar mount you'll have room to add and electric power steering motor!!
Old Apr 19, 2017 | 08:43 PM
cagotzmann's Avatar
cagotzmann
Here is another option. They have many kits, from complete to the individual parts required.
https://www.summitracing.com/int/parts/awr-hmgm01201sr
If you wish to see how this works review my T56 install notes.
https://www.corvetteforum.com/forums...-corvette.html
Old Apr 19, 2017 | 09:44 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
Out of curiosity, why change from the z-bar? After having had various issues with different hydraulic clutches over the years, I kinda like the ease and simplicity of the zbar arrangement.
Old Apr 20, 2017 | 11:08 AM
SteveG75's Avatar
SteveG75
Just bouncing ideas around my head.
I am using a Quicktime Bellhousing to mate the LS Magnum T56 to my 496 BBC. This bellhousing was modified to use the clutch pivot ball. I was tweaking the clutch linkage the other night to adjust engagement position and just got to thinking about hydraulics. I have the McLeod RST with a 25# Hays flywheel. I am also using the Speeddirect linkage rods. It works well for me though I do get a little rattle at idle with the clutch engaged in neutral. We did have to modify (shorten) the lower rod to get the clutch fork in the right position but it is all good now.
Old Apr 20, 2017 | 02:07 PM
OldCarBum's Avatar
OldCarBum
Check out Wilwood and american powertrain (Tremec)
Old Apr 20, 2017 | 09:27 PM
cagotzmann's Avatar
cagotzmann
I started with a ACT GM6-HDSS single disc clutch, Now have the Mcleod RST with a RAM 2530 Alum flywheel. I don't notice rattle at idle, but I do have rattle during acceleration ~ 2500 RPM.
I used the Hydraulic TOB from day 1. I never thought about using the old linkage setup. I wanted a very light pedal feel.
Old Jan 25, 2024 | 07:22 PM
kungfushirtartist's Avatar
kungfushirtartist
Cruising
Default Ls swap
If you do a LS swap in a c3 Corvette only one set of headers are made that clear the Z-bar and they 1,500 so that’s why I have to change.
Old Jan 25, 2024 | 09:55 PM
71 Vert LS1's Avatar
71 Vert LS1
Maybe no help but I was too cheap to do the hydro clutch on my 73 Camaro with a LS3/TKO 600 combo. Made the linkage out of 3/8" rod ends and 1/2" tubing. Then made a mount so I could use the bolt hole on the engine block. A bit of adjustment and it has worked great.
See pic.
Old Jan 26, 2024 | 01:21 AM
vettebuyer6369's Avatar
vettebuyer6369
You are addressing a post from 7 years ago.
To Bowler Hydraulic Clutch Conversion Kit
