motor for engine build
Old Feb 22, 2009 | 11:03 AM
timd02's Avatar
timd02
Default motor for engine build
I found a 5.7L chevy vortec engine with a 10243880 block casting number in my area. From what I have read it is a 96 and later motor. will this engine work for a build to go in a 75 corvette? I know it has a one piece rear main but what mods do you have to make to accomidate this?
Old Feb 22, 2009 | 02:20 PM
jackson's Avatar
jackson
It requires a different flywheel/flexplate than your 75 has ... bolt pattern & balance are different beginning 1986.
All 96up have electric fuel pump ... blocks' fuel pump boss is probably not completely machined ... you have to look. A local shop charges $75 to finish.
They also have an OE thin metric ringpak ... helps bore last long time; ensure your rebuild uses thin ringpak and NOT like what's in a C3. A pal just got a "new" 2008 Z71 pu ... & just sold his 96 Z71 pu w/ iron 350 vortec (vincode "R") ... he bought it new & maintains his stuff real well ... that 96 had about 150K and ran as well & quietly as new & no smoke & no oil use.
W/ roller lifters & vortec heads, a 96up "R" vortec motor is good choice as a core for rebuild.
-edit-you probably know its vortec heads require different intake manifold than your 75 ... also your shallow vette oil pan (~7") won't fit either. No waffling here, still a good choice to build for a 75.
Old Feb 22, 2009 | 02:48 PM
timd02's Avatar
timd02
I know that you have to use an 8 bolt intake for this type engine but what about the oil pan? Does anyone make an oil pan to fit this type motor and be able to fit the frame of a 75 vette?
Old Feb 22, 2009 | 03:25 PM
BLOCKMAN's Avatar
BLOCKMAN
You can use the old 2 peice rear seal crank in that block if you want to and they make 2 different adaptors one for the earlier pans and one for the late pans.
Old Feb 22, 2009 | 05:47 PM
timd02's Avatar
timd02
So what are your thoughts on this engine as a platform for a rebuild and upgrade? I am also looking into the Dart SHP that you told me about as well as a Lunati short block, they are only about an hour away from me. Here is the link to the motor I am looking at.
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Old Feb 22, 2009 | 11:02 PM
BLOCKMAN's Avatar
BLOCKMAN
I see it has PM rods and I have seen enough crate engines with broken rods and it looks to be just a cast crank as well, No matter what the block still should be checked out.
Good luck which ever way you go.
To motor for engine build
