Holley carb advice needed
Old Feb 22, 2009 | 03:59 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Holley carb advice needed
I have a 750 double pump with a man. choke. I need to cut off the top choke portion due to clearance problems. I have had carbs in the past with this part cut off. What method and tool should I use to cut this off?
Mike
Old Feb 22, 2009 | 04:31 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
I have have used a drill press with a cut-off wheel.
Old Feb 22, 2009 | 08:19 PM
midyearvette's Avatar
midyearvette
i have actually done this by hand by taking the carb apart and holding it square on the work bench and using a good hacksaw!!...replace the vent tubes with some steel fuel line pieces and jb weld.......really i have done three of them with super results . you can clean up the inside venturi's with 400 sand paper by hand too......i have read somewhere to leave some of the choke tower for flow over the boosters. mine is flush with the top of the gasket surface lip and works perfectly...good luck another way is with a band saw if you have one
Old Feb 22, 2009 | 09:35 PM
baxsom's Avatar
baxsom
you could always go to ebay and buy a proform center section that already has the tower milled off.
To Holley carb advice needed
