'79 L82 all Original - Sludge in Engine
Just bought a '79 with L82 Engine. Car is in mint condition.
The engine runs absolutely fine with no problems.
However when I pull the dipstick I can see that there is sludge
in the oilpan.
I do not want to fix somehing that isn't broken but what do I do now?
Just frequent oil changes to 'clean' it or would anybody recommend
to have the engine flushed ??
What kind of oil would you recommend ?
Every help is appreciated.
Thank's
Thomas
If it were my car:
- wouldn't take it on the highway for now
- run it hot with city driving, stop-n-go
- get a bottle of engine flush at discount auto
- follow the instructions as in let it idle only, don't drive
- change the oil and filter
- all of the above
Wouldn't be a bad idea to change the hoses and belts while you're at it.
Then take it for a couple of highway runs..enjoy..
The diesel oils like Rotella, Delo, Delvac, etc have good detergent additives and that is what I would use.
I have seen more than once where someone flushes an old coolant system or motor with flushing stuff. If you flush the motor you take a chance that you will loosen everything up holding that motor together. It will leak like a sprinkler...then you will have to tear into it. Drive it and change the oil several times.
Is your oil pressure good? Any loud tapping or knocking? Go with the least intrusive first....
Rd
in the oilpan.
Thank's
Thomas
I had a 80 with sludge and did the above it took some time to get it clean but it did come clean. I wanted to know if there was sludge in the top end of the motor. You can pull a valve cover or what I did was pull the distributor and when I did the shaft housing was full of sludge. I knew the whole engine was full of it. You need to disolve sludge slowly. You don't want chucks coming out because if chunks are falling out of the oil pan then chunks are falling in other parts of the motor.
In your shoes, I'd simply use a full synthetic, because they are really good at cleaning engine internals, better than dino oils, and then change the oil and filter extra often. Once you're satisfied that things are clean enough for you, return to normal change intervals and use your favorite oil. I'm not sure which viscosity you want to run, but Castrol Syntec 20W50 full syn, has extra zinc/phos in it for older flat tappet type motors. So, maybe you could consider that. Otherwise, Royal Purple is so good at wear protection, from its proprietary Synerlec additive, that even their street oil with reduced modern levels of zinc/phos will still prevent flat tappet issues. I've used it myself in a 283 without issue. Also the brand new lower zinc/phos Castrol "Edge" full syn motor oil has such good wear protection, that it also would be worth considering even for a flat tappet motor. It even advertises 8X better wear protection than Mobil 1. Another good anti-wear full syn is Valvoline Synpower which advertises 4X better wear protection than Mobil 1.
So you have several choices of oil to use, but full syn is your best bet, and DO NOT FLUSH the engine. Do things nice and slow, you'll be glad you did.
SH-60B
Whenever I pulled the Dipstick the tip always had debris attached
to it which was no metal. But the particles all had a crystalline condition.
Honestly I had no experience with this problem up to now but figured
based on researching the Internet that this got to be sludge.
I decided to use Seafoam and did the first run today.
Put appr. 5oz in and ran the car for like 10 miles very smooth with max 2500 rpm.
Changed oil and filter. Engine runs smooth with no problems.
The dipstick shows significantly less sludge.
I will repeat this procedure no a couple of times.
That way I think I will not risk any damage and will have a clean
engine in a few hundred miles.
540 Rat
I know that he 'Oil question' is always a delicate issue, as well in germany where I am originally coming from
but I heard that those 'old' small blocks should not be run with
synthetic oil. But I must admit that I have no personal experience
since I just bought my '79.
So I appreciate every good advice.
Thank's
Thomas
My engine machinist reccomended to use STP too because it has a high ZDDP package and costs alot less than others like GM's EOS.
+1 on the frequent oil / filter changes to clean it out. Personally, I'd drop the pan first and clean it, the pump pickup, and anything else in need.
