coil question
Old Feb 25, 2009 | 03:52 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default coil question
hi all, i have a 1978 l-82 that has 25500 mikes on it, i changed the plugs the other day during a header install. my question is does the coil need to be replaced due to it's age? i am getting ready to change the cap and rotor and didn't know if the coil could get weak with age. the car runs fine so i thought i would get some advice...
Old Feb 25, 2009 | 05:39 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I think that as long as the coil is not damaged or badly corroded, it does not need to be replaced. It doesn't really wear out.
Old Feb 25, 2009 | 07:08 PM
71coupe454's Avatar
71coupe454
look for hot spots maybe? there may be another/different visual, I forget.. But your gonna have it all apart anyways, slap in a new one..
Old Feb 25, 2009 | 07:27 PM
69elky's Avatar
69elky
Default coil
The old addage applies,if it ain't broke don't mess with it,carry a spare!Kidding aside I would leave it alone unless you are upgrading your ignition system to get better performance and the major suppliers all have decent ignition kits you can install.
Old Feb 25, 2009 | 08:31 PM
7T1vette's Avatar
7T1vette
If the top cap is not cracked and leaking off its charge, it should be fine. You can check resistance of the primary and secondary coils, but that really doesn't test the unit for integrity at full voltage on the secondary side.
Old Feb 25, 2009 | 08:58 PM
Duke94's Avatar
Duke94
A lot of the aftermarket coils are cheap copies of the original GM HEI coil. So you might be better off keeping your original. But, if it were me, I'd buy a new GM coil since yours is 30 years old.
Old Feb 25, 2009 | 09:26 PM
72LS1Vette's Avatar
72LS1Vette
If the engine is running OK you probably don't need to replace the coil. If the coil is in good shape cosmetically it might be worth storing it and putting in a new one if you are interested in NCRS-type judging at some point. I'm assuming you have the HEI ignition so there should be plenty of voltage to the plugs even if the coil is a little weak. Older points-style coils only put out 15-20K volts so when they got weak or developed some other ignition problem it was much more noticeable.
Rick B.
To coil question
