Cooling
Old Feb 26, 2009 | 05:25 PM
Schaggy's Avatar
Schaggy
Default How about this?
How about running 180 at car-cruise speeds (20mph-ish) and 210+ on back-roads? Slowing down on the back roads brings temps down.
Does that behavior indicate anything in particular?
Old Feb 26, 2009 | 05:44 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Retarded timing and lean A/F ratio will make anything run hot. That is where I would start. A pro can set the timing where the book calls for but if your mechanical advace, vacumn advance and advance curve are incorrect you will still run retarded. A lot of these cars sit, get a little condensation in the distributor and the centrifical weights freeze up, the vac can diaphram leaks or lower plate gets a little corrosion and don't advance properly. This is more common than you think and using a timing light setting initial don't catch it.
Old Feb 26, 2009 | 06:48 PM
SIXFOOTER's Avatar
SIXFOOTER
No it doesn't. It sounds like your system is working pretty well despite missing the spoiler
