Speedometer Light:
Old Feb 25, 2009 | 07:58 PM
Kevins77's Avatar
Kevins77
Default Speedometer Light:
Well crap.
My speedometer light just went out on the car on the way back a little while ago..
What is the best way to replace the bulb? Any way to do it without pulling the whole cluster?
Thanks!
Old Feb 25, 2009 | 08:16 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Depends on which bulb blew. Boy, you'll need some small hands. I can't do it!
I do not advise this method! The dash pad can crack right in the middle of the two gauges.
I did see someone do it this way! They took the three dash pad screws loose at the top and remove the two from the end of the dash pad. Once this is done they remove the lower column cover and take loose the two bolts that hold the steering column. With these things done you can pull back on the side of the dash pad and reach inside.
Willcox
Old Feb 25, 2009 | 08:21 PM
7T1vette's Avatar
7T1vette
If I recall correctly, there are 4 bulbs [each] in the speedo and the tach.
Old Feb 25, 2009 | 09:00 PM
Kevins77's Avatar
Kevins77
I only had one working bulb, which lit up the entire left/middle of the speedo.. so unless I was going well over 100 I was fine. One of those "I'll get to it later" items... well it just became a priority.. haha.
Old Feb 25, 2009 | 10:41 PM
Young69Owner's Avatar
Young69Owner
Willcox
I did it this way! ...and I bought my bulb sockets from you too! Four bulbs in speedo, four in tach, five in center console. Bulbs are 1895. There are two nuts on the firewall that you can also take out. BTW - I do not have small hands!
Old Feb 25, 2009 | 11:22 PM
0Willcox Corvette
Former Vendor
I'm glad you did this and did not damage anything.
My statement about small hands was if you were to try and reach up under the dash without taking anything out. Even if I could physically still do this, my hands are too large to reach up from under the pad and pull the bulb sockets loose. (Geo-Rilla Hands).
Pulling the pad away from the dash as mentioned can be done, but you do run the risk of cracking the pad.
Willcox
Old Feb 25, 2009 | 11:40 PM
Young69Owner
The area just above the steering wheel deforms a little bit and that upsets me, but it goes right back. I am good on the hands, I can only reach the turn signal indicators with everything buttoned up.
Old Feb 25, 2009 | 11:57 PM
Kevins77's Avatar
Kevins77
Willcox
I may have to make the girlfriend try it for me.. she has little hands and is willing to at least attempt to help.. haha.
My dash pad is already cracked over the speaker areas.. needs replaced.. so I guess a crack in that pad isnt the worst thing that could happen in my case.
Old Feb 26, 2009 | 12:17 PM
mrmarchuk's Avatar
mrmarchuk
simple fix if you dont mind it being different
buy some LED flexible strips at walmart or fleabay and glue them to your speedometer faceplate like so:
you can also do the same thing with your center cluster (gauges)
looks pretty good imo. but u cant dim it, its either on or off:
if youre interested, search for one of my threads i outline how i did it.
my my .02
edit:
looks bright and blurry in the pics cuz i took the pics without flash in poor lighting. theyre not too bright
Old Feb 26, 2009 | 12:45 PM
Kevins77's Avatar
Kevins77
Now THAT is slick.. I may have to look into that.. haha.
Old Feb 26, 2009 | 02:11 PM
mrmarchuk's Avatar
mrmarchuk
ALOT easier than switching out bulbs in the speedometer
you can get different colors as well, theres white, yellow, red, blue, green and maybe some in between that i missed
Old Feb 26, 2009 | 03:56 PM
Fuelie74's Avatar
Fuelie74
Remember if you switch to LEDs in the dash you won't be able to dim them like a condesent bulb.
Old Feb 26, 2009 | 05:43 PM
mrmarchuk's Avatar
mrmarchuk
yup. either on or off. although... i wonder if voltage effects it... i know those LED strips range from 8-15 volts in which they will work. i wonder if less voltage = less bright?
Old Feb 26, 2009 | 09:08 PM
Young69Owner
That looks great. I have blue 1895 LEDs in my center console and red ones on the business gauges. Mine are not set up to dim (plugged them into a different outlet on the switch), but I was pretty sure you could. They do dim with less voltage.
Old Feb 27, 2009 | 10:20 AM
mrmarchuk's Avatar
mrmarchuk
yes but the stock system (the stock bulbs) dim with less current i believe so theres no way to dim the leds unless you do some rewiring
Old Feb 27, 2009 | 12:41 PM
joewill's Avatar
joewill
I just got done restoring my cluster and console, and tieing up and bundling up my wiring better. I had to replace several of the bulbs,, now it is all nice and bright at night.. yes if you can get it to pull out out about 3 inches by removing the trim and screws, it is alot easier... plus.. take out your seats.. it is 4 bolts and you can get up in there alot easier..
Old Feb 27, 2009 | 03:05 PM
Young69Owner
So I guess the LEDs will take what they need no matter how much you dim them? What if you dim them almost all the way?
To Speedometer Light:
Old Feb 27, 2009 | 05:12 PM
Kevins77's Avatar
Kevins77
Well, I went ahead and just pulled the dash trim apart a bit last night and was able to replace the bulbs from below.... talk about a long process in an awkward position.. haha.
Old Feb 28, 2009 | 10:52 AM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Do you run a separate switch for the LEDs or tie them into the original headlight switch on the dash?
Dave
Old Feb 28, 2009 | 02:02 PM
mrmarchuk's Avatar
mrmarchuk
no, its just that they barely take any current at all. if u give it more, its got resistors which limit it to X ammount. if you dim it, youd have to dim it to almost nothing, then it might go a LITTLE darker before shutting them off
