MSD Location
Old Feb 26, 2009 | 11:31 AM
Mick 72's Avatar
Mick 72
Default MSD Location
I have a 72 with an automatic and A/C and I'm trying to figure out what's the best location to mount an MSD 6A box. I would prefer to leave under the hood with a stock appearance at first glance but I'm aware that with the bright red MSD distributor cap it's not going to be that big of a deal if it's not. Any suggestions?
Old Feb 26, 2009 | 11:40 AM
gatorbcn's Avatar
gatorbcn
I mounted mine behind the passenger side dash
Old Feb 26, 2009 | 11:55 AM
Mick 72's Avatar
Mick 72
Thanks. Did you have to remove anything or is there somewhat easy access?
Old Feb 26, 2009 | 12:07 PM
gatorbcn's Avatar
gatorbcn
Wasn't bad. Removed the center section and front cover with the map pocket. Mine is a '74, so my dash may be a little different than yours. Did you search posts on this topic? I know that it shows up from time to time.
Old Feb 26, 2009 | 12:23 PM
bluzman2004's Avatar
bluzman2004
MSD 6AL is right behind the stereo in the console and the Fuel Injection computer is behind the glove compartment. 78'
Old Feb 26, 2009 | 12:34 PM
Mr. Beam's Avatar
Mr. Beam
Some pics here
http://forums.corvetteforum.com/c3-t...aton-help.html
/Mr. Beam
Old Feb 26, 2009 | 01:42 PM
Mick 72's Avatar
Mick 72
Default Thanks for the info
I had originally though of the compartments behind the seats. You guys are great. I would have never thought of half the places. I see most are not inside the vehicles but I'm asuming to the ones that are inside there haven't been any overheating problems or shorts that may cause fire.
Old Feb 26, 2009 | 01:46 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Left front fender, just in front of the vents.
There is no reason to mount it inside the car, it's made to be outside.
Old Feb 26, 2009 | 06:22 PM
MAGDANA's Avatar
MAGDANA
I was told to mount it away from heat. Ended up putting it up under the dash and wiring through the firewall. Never had a problem.
Joe Johnson
www.MAGDANA.com
Old Feb 26, 2009 | 07:15 PM
bobio777's Avatar
bobio777
I put mine on the right side tucked up behind the washer tank and the overflow tank. i paint the MSD cap and coil black so that it isn't visible under the shroud.
Old Feb 26, 2009 | 09:40 PM
trw's Avatar
trw
I sprayed mine black and pulled the splash panel under the drivers fender and used double sided tape and stuck it to the firewall.
There are enough vacuum hoses in that area that I run the wiring with them.
Nobody has ever even seen it.
Old Feb 26, 2009 | 09:57 PM
curtis75's Avatar
curtis75
I bolted mine behind the passenger side wheel, tucked up nice and high so its hard to see. If you werent looking for it you wouldnt see it.
Old Feb 27, 2009 | 12:07 AM
Z-man's Avatar
Z-man
Me too. If you've got a '72, you can access it by taking off the egg crate grill.
Old Feb 27, 2009 | 12:42 AM
682XLR8's Avatar
682XLR8
Same here, up behind the w/w fluid reservoir
To MSD Location
