Stronger half shafts?
Old Feb 27, 2009 | 06:51 PM
kellyr073's Avatar
kellyr073
Default Stronger half shafts?
finally made the decision to swap out the 350/270HP with a 383/440HP crate motor with 465 ft lbs of torque. I'm replacing the drive shaft U-joints with the heavy duty one's in the ZIP catalog. Should I do the same for the half's?
I keep hearing that I will probably bust the half shaft U's or twist them. I don't think this should be that big an issue with this motor, it's not only a small block, right?
I saw a picture on another thread about MT Drag tires of some halves that look like twisted wet noodles. I'm not putting MT drags, maybe just Nitto 555's 10 inch wide. Should I be concerned? Are there stronger half's or U's that I should swap out? I really don't want to bust one out on the road.
Thanks.
Bob
Old Feb 27, 2009 | 08:16 PM
Paul71LT1's Avatar
Paul71LT1
For some reason as the HP went down, chevy beefed up the half shafts. I think it was in '76 that they went to a larger dia shaft and u-joint. Pull out any of the major catalogs and look them up and you will see the shift to larger shafts at some point in the late 70's. Use those and you should be all set.
Old Feb 27, 2009 | 08:26 PM
ED69ray's Avatar
ED69ray
Thanks.
Bob
If you are not running slicks and hooking up well enough to loft the front wheels i think you are fine running stock drivetrain components. At 450hp with street rubber the rear end should unload before destroying the drivetrain.
Its the high rpm launches and the abrupt loads they place upon the drivetrain that kills the components.
I am using solid joints, standard U straps, and french locks on the shafts for my 400/400 sb build '69 model - should be fine for a street driven car.
Thanks, Ed
Old Feb 28, 2009 | 12:13 AM
7T1vette's Avatar
7T1vette
And...what about the driveshaft joints and the rear gear?
Old Feb 28, 2009 | 12:55 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The 1965-1979 rear suspension is one of the better suspension set ups you will find for standard or high performance output. IMHO, the darn thing is pretty much indestructible.
In the early 80’s we would go to the Corvette Homecoming in Bowling Green to set up at the swap meet. Every year they would have the King of the Blue Grass drags for the Corvettes and one item we would always take a boat load of as the Spicer U-joints. We sold the hell out of them from the people racing.
IMHO and from personal experience! I’ve broke one spindle, and probably a few dozen U-joints. The spindle was broken on a car twenty years ago too!
Two years ago we built a 383 for a 65 conv that did win the King of the Hill, (new name for it I guess) with Air Flow Research Heads (no juice)., a ton of mods, and ran a 11.61 1/4 with no suspension damage (and with slicks).
Your weak point on this suspension is the U-joint, and then I would have to say the spindle, but the half shafts will take just about anything you can give them. I think you will be just fine with the shafts.
Willcox
Old Feb 28, 2009 | 02:59 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Tho I've never run slicks on my NOM '78, I have broken my share of IRS bits over the years, and have thus methodically replaced/upgraded nearly everything, including HD 12-bolt IRS conversion; sole exception being the factory HD half-shafts. So, I can attest that they're indeed stout. But, having learnt the hard way that given enough power and sufficient bite something is eventually going to break, I admit to considering changing them out in preparation for the fresh 500+ HP 427 I'm in the process of building up.
FWIW, if you have a stick, do yourself a huge favor and get a ~15# flywheel. Not only will it greatly reduce the shock to your drivetrain, but it will promote easier shifting (especially down) during spirited driving. In any event, I suggest only Spicer solid U-joints behind high-perf mills, and to make sure your suspension doesn't squat excessively under acceleration so as to not bind a U.
TSW
Old Feb 28, 2009 | 07:27 AM
ED69ray's Avatar
ED69ray
TSW
thats what I wanna hear, I am going with a 15lb flywheel/10.5in clutch on my '69 sb - M-20 tranny w/ 3.70 rear also
Old Feb 28, 2009 | 08:14 AM
GTR1999's Avatar
GTR1999
with under 500 hp, st tires, no hard continuos launches the 3" with solid spicer are all you need.
The parts that break inside the diff are the posi cases,spiders. The 65-68 were not too strong and often are crack prone. The 69-79 are better but in stock form still weak to an extent.
Zerk joints are a waste of money and have failed in non racing use.
Rear spindle damage a lot of time is due to bad bearings locking up.
High power will break a lot of these parts so it all comes down to how much you have and how you drive.
Old Feb 28, 2009 | 11:34 AM
TheSkunkWorks
Originally Posted by GTR1999
...The parts that break inside the diff are the posi cases,spiders. The 65-68 were not too strong and often are crack prone. The 69-79 are better but in stock form still weak to an extent...
Yes. I've cracked a 10-bolt case at the window and have broken spiders and pinion shafts (the shaft connecting the spiders), on one occasion spitting parts out thru the housing. After that last one, that's when I had my first 12-bolt done. BTW, Gary, I may send that one to you this summer to be rebuilt and upgraded to full HD.
Old Feb 28, 2009 | 12:34 PM
toddalin's Avatar
toddalin
I would (and did) get rid of the SB half-shaft U-bolts and upgrade to the BB end-caps in the pumpkin. I also replaced the U-joints with Zerk fittings with solid units.
This was after one of the U-joints let go and took out the rear end and did lots of other damage back there (>$3K). I had a half-shaft actually come into the car when shifting into 3rd at the 1/4 when the U-joint let go. This was right after I just had the entire rear-end replaced due to failed spider gears (from launching in the 1/4 on street tires with lots of VHT on the track surface..., also ~$3K).
To Stronger half shafts?
