Gasket help
Old Jan 25, 2002 | 10:45 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default Gasket help
I need to replace the valve cover and exhaust gaskets on my vette. I would like to know what brand is the best to use. I also need information on which exhaust gasket to get round or square?
Mark B.
[Modified by Sigforty, 8:46 PM 1/25/2002]
Old Jan 25, 2002 | 10:49 PM
82dukman's Avatar
82dukman
Default Re: Gasket help (Sigforty)
Can't help with Exhaust gaskets but valve cover I only use Felpro. use the rubber ones if you can find them. If you have to use the cork, make sure you pre-soak them with oil before installing on the car.
