1980 Alternator Sizes
Old Mar 1, 2009 | 06:39 PM
Smadoo's Avatar
Smadoo
Default 1980 Alternator Sizes
I'm replacing the belts on my 80. When I went to buy the belts, the guy at the store asked if I have the 70 amp alternator. How can I tell if I have the 70 amp?
Old Mar 1, 2009 | 06:57 PM
wfo76's Avatar
wfo76
Should be stamped on the alternator after alt number,
ie: 1101075 70A
Basically if you have rear window defog, you should have 70 amp,
if not probably will be 61 or 63 amp
Old Mar 1, 2009 | 07:05 PM
Rich N.'s Avatar
Rich N.
Default '80 alternator belt
Samdoo, I have ' 81s, but I believe they are the same. 70 amp is OEM, but many people change over to 100 amp when the alternator needs replacing. a PO may have changed your alternator. some of the cheaper rebuilds are not marked or painted over. an experienced parts guy should know by looking at it. the 100 amp is fatter. they are cheap enough to get the OEM belt and the next size longer. if 100 amp, it may hit the valve cover unless the belt is longer. good luck.
Old Mar 1, 2009 | 07:21 PM
thegazman's Avatar
thegazman
Default thegazman
What's the number on the old belt?
Old Mar 2, 2009 | 02:51 PM
Smadoo's Avatar
Smadoo
The current alternator was replaced by the PO(who also managed to break the lower alternator bracket) so I didnt necesarilly want to go off of that. My car does have the rear defroster as well as the power antenna and door locks. Based on the amount of power those would draw, i assumed it would be the heavier one.
Jim
Old Mar 3, 2009 | 06:55 PM
stellar's Avatar
stellar
Look at the rear of the alt. If the back of the case is flat except for the bearing it is a 63 amp. If 1/4 of the case is recessed it is the 70 amp.
Old Apr 27, 2009 | 02:02 PM
Grumpy 427's Avatar
Grumpy 427
I just looked at mine, and it is the 70 amp. Under what circumstances would you need to upgrade to a 100 amp? Is it required? can you make a 100 out of a 70 by changing the windings or is it a bigger case as well.
Old Apr 27, 2009 | 06:27 PM
stellar's Avatar
stellar
The 70 amp unit was an excellent unit. Unless there is additional electrics added from stock I would keep the 70 amp in there. Upgrades are possible in the same size case by changing windings. Depending on amount of upgrade will determine if reg and rect will need to be changed along with the bigger windings. Mark
To 1980 Alternator Sizes
