Help with door handle
Old Mar 2, 2009 | 12:15 AM
77OrangeL-82's Avatar
77OrangeL-82
Cruising
Default Help with door handle
My 77 has been difficult to open on drivers door and last week failed to open at all. Had to use the inside handle. I pulled the door panel today ( lubed the power window which had not seen lube in 31yrs - thought I might need a new motor ) anyway I have the shop manual and haynes? neither of which address door handle. Can't see how to get dust shield out and don't know how to save the clips holding the rods which seem to need to be disconnected. I can see a spring which seems to be disconnected but sure could use a diagram of the handle. Can anybody recommend a manual that shows these. Got any idea of what parts to order? Anyway thought I would throw this out to you master mechanics before I take to my Vette guy who usally will have it for at least a week.
Art
Old Mar 2, 2009 | 11:44 PM
20mercury's Avatar
20mercury
Default Had same problem on my 76
Had the same problem on my 76. Outside handle was not working but the inside handle was. Finally figured out that the outside handle pushes a vertical rod down that is attached to the door locking mechanism that engages with the striker bolt. If you run the window down, pull the door panel off and look through the opening you can see the vertical rod connecting the outside handle to the door locking mechanism moving when you press the outside handle.
Now the trick, much patience and you will learn new words, you need to unclip the clip, and turn the threaded tee piece down maybe 3 or 5 threads depending on how much it is worn and rehook. I did this with needle nose pliers and by wiggling my hand in the door. This worked for me. If there is a better way, I sure would like to know too!
Hope this helps, I am not sure I know what spring might be disconnected. I think the AIM shows this, but I do not have a scanner.
Old Mar 3, 2009 | 04:59 AM
hunt4cleanair's Avatar
hunt4cleanair
Hey Art...this just came out in the May issue of Corvette Enthusiast but describest getting into the door panel to fix lock issues.
door lock repair
I repaired my door locks last year and simply dropped the shield down into the panel and than worked it back up when closing the side panel up.
Old Mar 3, 2009 | 10:44 AM
Kadorja's Avatar
Kadorja
My 80 had the same problem for a while. Actually it was so bad I couldnt get the door open from the outside at all or the inside. If I locked the door it was almost impossible to pull the lock open from the inside of the car.*power locks disconnected*
I ended up just rolling down the window and spraying everything I could see that had a hinge down with WD-40. It took it a few minutes of doing that and working the handle and lock but it ended up working. It was pretty odd actually if I pulled the inside handle AND the outside handle I could unlock the door and open it with ease. It saved me the trouble of ripping everything apart and its worked for a few months still.
Too bad everything else is broken or dying.
Old Mar 3, 2009 | 10:58 AM
cargo247's Avatar
cargo247
info for you.
http://www.corvettemagazine.com/tech...rticles/c3/65/
Todd
To Help with door handle
