Timing light question?
Old Mar 2, 2009 | 06:34 PM
BassCat's Avatar
BassCat
Default Timing light question?
I'm trying to dial my timing in, per Lar's instructions, but I don't have a dial back timing light. I've been to NAPA, Sears, AutoZone, and O'reillys, and looked at all of their lights. The most expensive ones have an "advance" button that it says is for precision tuning, but none of them say "dial back". Can someone tell me if these will provide the dial back function, or do I need to keep looking?
KC
Old Mar 2, 2009 | 06:39 PM
SH-60B's Avatar
SH-60B
Save your money and put a timing tape on the balancer. You don't even need to buy that, you can make your own.
Old Mar 2, 2009 | 06:47 PM
7T1vette's Avatar
7T1vette
Buy a "degree" tape for the diameter of your harmonic balancer. Then just read the actual 'advance' degrees off of the tape.
Old Mar 2, 2009 | 07:00 PM
BassCat's Avatar
BassCat
That sounds great. Do the parts houses sell those??
Old Mar 2, 2009 | 07:52 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Better still....
http://store.summitracing.com/partde...7&autoview=sku
Old Mar 2, 2009 | 08:04 PM
VictoriaVette's Avatar
VictoriaVette
I bought my timing light from Summit it is the type that you can dial in around $50-60 I think when I got mine.
Old Mar 2, 2009 | 08:06 PM
'75's Avatar
'75
The timing lights you saw with the advance feature are actually "dial back timing lights" by another name, same function.
Old Mar 3, 2009 | 07:52 AM
Paul L's Avatar
Paul L
Sears calls it "direct reading advance scale."
Old Mar 3, 2009 | 12:45 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I have 2 timing lights: a Sears model (no dial-back) and a Snap-On with dial-back. I prefer to use timing tapes or fully degreed dampers. Just my 2 cents.
Old Mar 3, 2009 | 02:21 PM
Reggie Dunlop's Avatar
Reggie Dunlop
You can get a good dial back light with a built in tach for around $100. Why fool around with a tape? I can use mine on any of my 4 cars and all other cars too and never have to be concerned if it a tape or not.
Old Mar 3, 2009 | 07:09 PM
mikep3's Avatar
mikep3
I got one of these;
http://www.iequus.com/product_info.p...tegory_id=1_20
Easy to use and has a tach, the arrow keys can be used to advance or decrease the displayed degrees.
To use, for example; I use the arrow key (advance) to bring the timing light mark on the dampener to zero and read the degree on the display for the timing advance at that rpm.
Sounds confusing, but with the timing light in hand and runs and it will all fall in place, or its something you should have others do for you.
Old Mar 3, 2009 | 09:24 PM
BLOCKMAN's Avatar
BLOCKMAN
Here are some good links to look over
http://www.dragracingonline.com/tech...-lights-1.html
http://www.chevytalk.org/fusionbb/sh...hp?tid/173877/
Old Mar 3, 2009 | 10:48 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I picked mine up at Sears. "Dial Back" is just a slang name for them as I am sure you have figured out by now.
Old Mar 4, 2009 | 06:40 AM
BassCat's Avatar
BassCat
Man, you guys are great. I know what I'm looking for now.
KC
To Timing light question?
