TH350 Transmission leak
Old Mar 5, 2009 | 09:58 AM
oneshot's Avatar
oneshot
Default TH350 Transmission leak
Hey Guys,
I have a TH350 transmission that has a small leak from the shifter linkage. Does anyone have a write up that shows how to take that linkage out and replace the O ring. I am not sure how hard of a job that is considering it is a very small leak.
Old Mar 5, 2009 | 10:16 AM
dobroman2001's Avatar
dobroman2001
Originally Posted by oneshot
Hey Guys,
Here's some Pics I took when I changed mine. I used this tool that threads into the old seal and removes it..
http://s189.photobucket.com/albums/z...Seal%20change/
Old Mar 5, 2009 | 10:25 AM
oneshot's Avatar
oneshot
It looks as simple as....
1.)remove shifter linkage
2.)remove the outer seal
3.)press the new seal over the linkage shaft
The tool you used to remove the old seal and put the new one on. Where did you get it?
Old Mar 5, 2009 | 10:49 AM
dobroman2001
yeah, that's pretty much it...
If you want to borrow the tool (or buy it) we can work something out... Just PM me..
Tab,
Old Mar 5, 2009 | 11:06 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I've seen the tool a lot cheaper but can't find it...
http://www.tooltopia.com/index.asp?P...OD&ProdID=5475
Old Mar 5, 2009 | 11:10 AM
dobroman2001
Originally Posted by Jud Chapin
I seen the tool a lot cheaper but can't find it...
Yikes, I think I paid something like 25 or 35 dollars for it....
Old Mar 5, 2009 | 11:16 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Double YIKES!
I was planning on buying one too!
Maybe put me on your rental list!
Dropped the pan last year to change fluid and filter, hate to do it again, but for $100+ I probably will...
Old Mar 5, 2009 | 12:08 PM
oneshot's Avatar
oneshot
http://buy1.snapon.com/catalog/item....&group_ID=1617
I think this is what you got.
Let me see if I can find one local. If not, I will PM you.
Old Mar 5, 2009 | 01:37 PM
dobroman2001
Yep, that's it...
Old Mar 5, 2009 | 07:41 PM
noonie's Avatar
noonie
You will find the tool made by Lisle or KD listed on a bunch of websites, but they won't be able to deliver.
Mine old one disappeared last summer and eventually called the distributers and found that they were discontinued.
Ended up getting another one from Snapon, shipping is free btw and it fits all GM auto trannies.
To TH350 Transmission leak
