tilt column
Old Mar 5, 2009 | 03:52 PM
glo's Avatar
glo
Default tilt column
Will a 79 tilt steering column work in a 77 .I looking at swapping out the 77 with 79 tilt column .Just want make sure I can.
Old Mar 5, 2009 | 06:42 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
Should fit... They do have a way of changing stuff like the dimmer switch and wiper switches over to the column on later cars..Not sure about late C3s.. You may want to fix the existing one and keep things correct..
Old Mar 5, 2009 | 06:57 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Like mentioned, the wiper/wash control is located on the column for 77, NOT for 79. Both years do have the dimmer on the column.
Old Mar 5, 2009 | 07:55 PM
glo's Avatar
glo
Yea,you are probably right in keeping what I got and fixing it .I just thought the swap would be the same .
To tilt column
