Sequence or logic controller
Old Mar 5, 2009 | 10:40 PM
Blain's Avatar
Blain
Default Sequence or logic controller
My '74 has what I have seen referred to as a logic controller or sequence controller. All belt, seat and door switches terminate there. Problem is none of the wiring diagrams I have found show how it is wired. I want to make it go away but need to know how it works first.
Anyone have a diagram?
Thanks, Blain.
Old Mar 7, 2009 | 10:53 AM
Blain's Avatar
Blain
Wow, nothing?
Old Mar 7, 2009 | 12:11 PM
Peterbuilt's Avatar
Peterbuilt
All diagrams http://www.nrjvette.com/johdotukset/?c=d;o=d PG.
Old Mar 7, 2009 | 04:24 PM
Blain's Avatar
Blain
Page 8 of the 74 diagram should be it. But not even close. Does your 74 have the same module?
Old Mar 7, 2009 | 05:11 PM
Peterbuilt's Avatar
Peterbuilt
I have not seen that part in my car, what area is that picture from.
In 74 only ( and some early 75's ) you had to fasten the seat belts to start the car, I disconnected that by going behind the seats and unhooking the connection. If you left that connected and the car won't start you can open the hood and press a button on the firewall to override the system. PG.
Old Mar 7, 2009 | 06:34 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
From what I can see in your picture yellow/black wire & a orange wire. Looking on the print it looks like thats the 3 wire connector.
separate & clean wire going into that thing & give us a better view.
Old Mar 7, 2009 | 09:58 PM
Blain's Avatar
Blain
Couldn't wait. Unwrapped the harness and removed all that crap. Really wasn't as bad as I thought. I have an electrical background so not too intimidated. Besides the cost of a new harness is quite a motivator.
Unwrapped.
Unnecessary junk.
Re-taped and ready.
Still would like a wire diagram if anyone runs across one.
Blain
To Sequence or logic controller
