Battery recharge.....
Old Mar 6, 2009 | 05:47 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Battery recharge.....
New battery (about 1 year old) from AutoZone (the top of the line)....Haven't driven the car for about a month.....came out this morning to finally drive it and found a dead battery. Have a battery recharger (12v / 6amps) on it now and will throughout the night. Do I need a new battery? or will it be OK for this time? The reason the battery ran down....electronic security system on the Vette....whenever I test for a "drain" of the battery, I get a very slight glow on the tester (security system = on) but when I turn off the security system, the glow goes away.
Old Mar 6, 2009 | 06:00 PM
bailey228545's Avatar
bailey228545
I would think it's going to be okay once you get it charged back up. If you are only driving it periodically, I would put a charger on it that will set itself to do a trickle charge once the battery has been fully charged. I just put a Optima red top in my '81 and I could not believe the difference in how fast it fires up now that it has a good battery.
Old Mar 6, 2009 | 07:05 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Charge it up you will be fine...you may want to purchase a Battery Tender to keep it topped up though.
Old Mar 6, 2009 | 07:39 PM
bluthundr's Avatar
bluthundr
The "security system" shouldn't draw any power when "armed. " It's just a glorified set of switches.
Old Mar 6, 2009 | 08:46 PM
wer2xu's Avatar
wer2xu
the only thing that would draw in a security system is the LED, or the proximity sensor, if you don't have any active components such as those you have a short somewhere.
Lead acid batteries like to be kept fully charged all the time, use a tender.
Old Mar 6, 2009 | 09:45 PM
vetteguy75's Avatar
vetteguy75
The security system I have is an AUTOPAGE & is connected to the starter (becomes disabled if the alarm goes off), it also has a mercury level switch, it also pages me if for any reason the car is jarred, bumped, or messed with in any fashion. The page can reach out 1 mile...great for when your in the mall or store or at home. So you can see there's alot tied to the battery. If I drive it at least 3 time per week.....no problems...it just when it sits for a month (first time) it drains the battery. Going to get a Battery Tender tomorrow.
Old Mar 6, 2009 | 11:41 PM
7T1vette's Avatar
7T1vette
Letting a regular lead-acid battery go completely dead is never a good thing for battery life. The best thing for them is to keep them fully charged all the time. Since it went to complete discharge, you really don't know if the battery is permanently damaged or not. Try to recharge it and see what happens. If you have a constant (or likely) drain on the electrical system, either find and fix it or install a battery disconnect switch.
Old Mar 7, 2009 | 09:27 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
As stated just charge it up, maybe you should install a quick battery disconnect switch for when the car sits. But a Battery Tender is your best friend if you car sits for extended periods.
To Battery recharge.....
