Valve stem/guide clearance ?
Old Jan 26, 2002 | 07:17 PM
shark's Avatar
shark
Default Valve stem/guide clearance ?
How tight should the play be between the stem and guide?
should I be able to feel a small play if I wiggle the valve at 0.5" lift ?
If a exhaust guide is slightly worn (can feel a play but hardly see it)
can I drive with it ? how long can I expect it to work ?
i only drive it about 1000 miles per year.
Old Jan 26, 2002 | 07:29 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: Valve stem/guide clearance ? (shark)
must be checked with a dial indicator
Old Jan 26, 2002 | 07:42 PM
shark's Avatar
shark
I have Dial indicator. How do I measure it what should the specs be ?
Old Jan 26, 2002 | 08:20 PM
Stingy74's Avatar
Stingy74
Guide wear can be reduced by using special length pushrods.
To Valve stem/guide clearance ?
