Advice on headers
Old Mar 7, 2009 | 11:14 AM
Bond007's Avatar
Bond007
Default Advice on headers
Hello Fellow Vetteheads,
I'am considering on installing a set of headers on my stock L-82
can anyone advise me on a company,model#,would like to have cermaic coated I believe, and do I have the oval or D exhaust port.
Car is stored for winter so I have not even taken it out yet, but am
getting ANTSY. I'am no mechanic but know a few things and mechanics for support. One other thing, who do I have to help me edit my profile, picture too big,Thank You in Advance.
Old Mar 7, 2009 | 03:11 PM
nate99's Avatar
nate99
Your choices are many. If your engine is staying mostly stock, the difference in terms of performance among the available options will not be that great. I would go look at what summit racing or jegs has listed for your car and you can get a good feel for what is out there. Quality and features will vary, and you will get what you pay for.
As for me, I have a set of Stan's Tri-Y headers about to go in to accompany my 290 HP GMPP crate engine, which is pretty much the same as your L-82 once de-smogged, I think. Stan's is a small shop that is known for their good quality and fitment. Since I was not going for all out HP, I figured that would be a good way to go for me, but your goals may be different.
Just do a search on this forum for threads with "headers" in the title and you will get tons of information.
Old Mar 7, 2009 | 03:17 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
A nice set of Heddman Elites should work fine for you. Jegs or Summit
Old Mar 7, 2009 | 06:15 PM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
I put on Patriot tight tuck headers last year.They fit great and look great. .Works good on stock exhaust on my 74. All came from Corvette Central.
Old Mar 8, 2009 | 11:39 AM
Bond007's Avatar
Bond007
Thanks for the help all, really appreciate it. Jbaron what did you do with the smog pump ,heat riser,etc.
Old Mar 8, 2009 | 11:43 AM
BigEarl's Avatar
BigEarl
I'm in the same boat as you. After hours of researching this forum and the web, I decided I'm ordering the Dynomax WLK 86008 tomorrow. Summit sells them for $325, but they should match the price that these guys have them for...
http://fastercorvette.com/1963-1982-...ed-p-8744.html
Old Mar 8, 2009 | 12:18 PM
hdff's Avatar
hdff
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
i decided to change the look of my stock 78 while i was trying to add a little sound , the stock exhaust was just way to quiet. i put on ceramic coated hooker header side pipes. i really like the agressive look that it gave and they sound GREAT!
Old Mar 9, 2009 | 04:40 PM
Drunken Peacock's Avatar
Drunken Peacock
Your L82 won't be D ports. That's on the ZZ4 motors. I went with the Headman Elites. Really nice performing and solid thick plate at the heads.
Old Mar 9, 2009 | 04:49 PM
BTAL's Avatar
BTAL
St. Jude Donor '09
Last spring got a set of new Flowtech ceramic coated from a member here. Easy install into a '78 L-82 4 speed. Only needed a little dimple to clear the z-bar.
Summit has them:
Flowtech 31106FLT
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 10, 2009 | 11:04 PM
jbaron's Avatar
jbaron
My car is a '74, no smog pump etc.
To Advice on headers
