A-arm rebuild
Old Mar 7, 2009 | 05:28 PM
Bubs's Avatar
Bubs
Default A-arm rebuild
I am stripping down the upper and lower control arms on my 73 coupe for a rebuild. I got the bushings and rod off the upper but the lower ones are a biatch. What is the easiest way to get these off?
Thanks in advance,
Bubs
Old Mar 7, 2009 | 06:22 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
First put new bushings in the freezer.
On the old bushings take a torch heat the shell till you can push out the rubber. Then take a punch /chisel Airhammer whatever & collapse the outer shells till you can pop them out.
Now clean out the A arm holes with some 120 grit sandpaper. Lube new shells with some light grease, install cross shaft through the holes in A arm. press new bushings in.
If you dont hav ethe special equipment....
Easiest thing to do is take it to a alignment or suspension shop flip the guy a $20 and ask him to press them in for you
Old Mar 7, 2009 | 10:04 PM
Droshki's Avatar
Droshki
An air chisel will take them right out. Really no other way.
To reinstall I was trying to use a press, but the guy that ran the shop (military auto hobby shop) just threw them up on a vise and popped them in with a hammer and a drift.
It was pretty obvious that this wasnt his first rodeo.
Old Mar 7, 2009 | 11:57 PM
71SoCal's Avatar
71SoCal
I just finished rebuilding the front-end on my '71. I paid a shop $25 to air chisel the old ones out, then later another $25 to press the new ones in.
I've read stories where the ears on the arms can get bent if not done correctly, so I stood right there and watched while they did it.
I actually still need to get the car aligned, but for now I just used a forum trick where I set 16' steel conduits along side the car on jack stands, then measured the leading edge of each rim vs.the trailing edge to get the toe-in close.
Good luck...
Old Mar 8, 2009 | 02:52 PM
Bubs's Avatar
Bubs
Thanks for all the advice. I will try the heat first as this is how I got out the upper ones but I am kind of leaning towards the shop. Thanks again, Bubs.
Old Mar 8, 2009 | 09:13 PM
69small block's Avatar
69small block
air chisel get them out or burning them but very messy and putting them in out cambend them the tool is shown in manual but i made one from 1/1/2 pipe cut for length and ears on cross shaft
To A-arm rebuild
