Stereo wiring
Old Mar 9, 2009 | 01:45 PM
ANY VETTE's Avatar
ANY VETTE
Default Stereo wiring
I am putting a used pioneer cassette in my car and don't know the wiring.Does anybody know what the orange wire does as well as black and green
Old Mar 9, 2009 | 02:58 PM
BigBlockTank's Avatar
BigBlockTank
What Pioneer? About from what year? You can google that model# and find a wire connection diagram, i bet.
Old Mar 9, 2009 | 04:34 PM
car71's Avatar
car71
orange could be memory, or speaker, black wire ground ,and green sounds like speaker wire maybe.most of the time red is power, blue it remote, and orange is memory,.
Old Mar 9, 2009 | 04:47 PM
spedaleden's Avatar
spedaleden
Most Pioneers were
Red = Power 12 volts key
Orange or yellow = 12 volts Hot all the time
Black = ground
Blue = power antenna
Bluew/white = Amp turn on
Gray = R+
Gray/black = R- Front & Rear
Green = L+
Green/black Left- Front & Rear
Gray/red = Right + rear
Green/red = Left + rear
Hope this helps but google your model number to get coorect codes per above
Old Mar 9, 2009 | 06:43 PM
ANY VETTE's Avatar
ANY VETTE
Thks Sedaleden you are right!
Old Mar 10, 2009 | 06:54 AM
Droptop-Rob's Avatar
Droptop-Rob
Originally Posted by spedaleden
Most Pioneers were
Black = ground
Gray = R+
Green = L+
Back in the day I also installed a ton of stereo's you might want to check the Red and orange. I could be wrong but I thought that Orange goes to 12v switched, red goes to 12v constant. Just my .02
Rob
Old Mar 10, 2009 | 02:03 PM
car71's Avatar
car71
Rob
I think the orange wire is the memory for the stereo, which has to have power to it all time, or you would lose the clock setting, a long with the preset radio stations ,and the red wire goes to the key switch that powers up the radio.
Old Mar 10, 2009 | 04:10 PM
sly vette's Avatar
sly vette
I believe this is correct also!
Old Mar 15, 2009 | 01:54 PM
Droptop-Rob
Cool, it has been a while!
Old Mar 29, 2009 | 07:10 PM
ANY VETTE's Avatar
ANY VETTE
I went to do the install this weekend and my problem is that I only have four speker leads-
gray
gray red
green
green red
Old Mar 29, 2009 | 07:28 PM
Ganey's Avatar
Ganey
Those should be the + as stated above. Black from Pioneer should be - on all.
Old Mar 29, 2009 | 07:45 PM
ANY VETTE's Avatar
ANY VETTE
So the black that leaves the deck that I now have directly to ground should go to one side of each speaker?
Old Mar 29, 2009 | 08:08 PM
boeing46's Avatar
boeing46
I have a new Pioneer DEH-P4000UB
yellow constant 12v power supply
red/12v controlled by ignition switch
orange/white to lighting switch terminal
black-to clean bare ground
left front speaker white+/white/black-
left rear speaker green+/green/black-
right front speaker gray+/gray/black-
right rear speaker violet+/violet/black-
system control for amp or auto antenna 300mA 12v max blue/white
For my Pioneer DEH-P4000UB bought and in stalled last year
The power antenna won't work so i have to take it back or find out if it took a dump
I took these right from the instructions for my Pioneer. If your lucky they have kept the same colors
Old Apr 23, 2009 | 10:28 PM
m010702's Avatar
m010702
these pics are of a couple of wires under the dash. are these the red and orange (power and memory respectively) you all are speaking of? thanks for the help, this is the last step in my stereo installation.
http://i657.photobucket.com/albums/u...2/IMG_0072.jpg
http://i657.photobucket.com/albums/u...2/IMG_0071.jpg
http://i657.photobucket.com/albums/u...2/IMG_0070.jpg
Old Apr 24, 2009 | 02:48 PM
MickeyG's Avatar
MickeyG
I used the codes from spedaledan and also Googled "Aftermarket Radio Color Codes" and got a couple versions for Pioneer
MickeyG
To Stereo wiring
