charging problem
Old Mar 10, 2009 | 09:20 PM
chadw's Avatar
chadw
Default charging problem
please help having a charging problem with my 82 crossfire .
Checked the alt. showed good.
the batteries' new.
Drove it today alt guage showed 13 when I started drove about 30 miles and it dropped to 8 then everything went dead. Going to start tearing into it tomorrow wondering what you would suggest to start with??
Old Mar 10, 2009 | 09:40 PM
wombvette's Avatar
wombvette
The alternator is not charging. How did it check good? Get it running again and look at the back of the alternator. You will see a D shaped hole. Inside that hole there is a small tab. Use a small screwdriver and ground that tab to the case of the alternator. Watch the gauge. It should charge at full force ~ 15V. If it charges the regulator is bad. If it does not charge the alternator is bad.
Old Mar 10, 2009 | 09:47 PM
chadw's Avatar
chadw
thanks wombvette, My charger has a alt. check on it thats what I checked it with. In my mind I think it's the alt. , I'll check it in the morning.
To charging problem
