'72 Wiper Door Malfunction
I'm sure this is not new to you veterans out there so someone can supply me a quick fix....right?
mine had a bunch of stress cracks in it, from constant flexing...un fixable...to just tee the 3 hoses into it, and forget about it...
OR, the wiper door vacuum relay has a leak in the control line going to it....
there are threads on that.....
Say where is that vacuum relay located? Also can you expound on what you said about "tee the 3 hoses into it"?
Also, the check valve idea is intriguing. I assume the check valve is in a vacuum line off the intake manifold? Can you tell me where it is located? Maybe when the engine is shut down the check valve leaks a little bit thus allowing the wiper door to raise a little. Then it begins to "hold" at a lower vacuum pressure? If the check valve was completely bad and/or if there was a "leak" in the vacuum system then the door would raise all the way up after engine shutdown?
Thanks for the replies!
You need to look at the large vacuum line coming from the intake manifold at the back of the carburetor for 2 things, a plastic inline filter and a metal inline check valve with one line in and two out.
cc
CC,
Ok let me try attaching another pic. I think I may have found what you are talking about...
[IMG]
[/IMG]
Hans
cc
PS did you ever get your wipers working from your other post?
Thanks for all of the helpful info. I ordered a filter and check valve from Bair's. Hopefully this wioll fix it.
CC, I never had any issue with the wipers on my car. They worked fine the only time I have ever used them (right before the wiper door malfunctioned). Maybe you are remembering a post from someone else?
I'll post and let everyone know if this fixed it. I should receive the new parts this week.
cc
. Wiper door still raises back up about 3/8 inch 4 to 5 minutes after engine shutdown. But this time, as I was bending over the right side of the car looking and wondering over the engine bay, I heard a sound like air rushing thru an orifice coming from under the right fender. It was the Wiper Vacuum Relay. I started the engine, let the wiper door seat and shut the engine down. I hear the noise between the 4 and 5 minute mark every time just before the wiper door raises up. Do you think it's a bad wiper vacuum relay or something between the relay and the bypass valve/solenoid valve arrangement under the dash that is the culprit???
cc
Below the diaphragm there are three hoses. The middle hose also has vacuum from the engine. The other two hoses go to the front and back of the actuator. Vacuum on one side of the actuator opens the door, and vacuum to the other side closes the door. The relay controls which side gets the vacuum.
Normally closed: Vacuum is applied to the diaphragm which is pulled up so the relay sends vacuum to the front side of the actuator. When you turn on the wipers, or pull the valve under the steering column, vacuum is cut off to the diaphragm so spring pressure pushes the diaphragm down which switches vacuum to the rear of the actuator which opens the door.
If your door is opening after you turn the engine off, you are loosing vacuum to the diaphragm side of the relay. There is enough residual vacuum in the system to open the door.
The headlight doors work exactly the same way. Some cars have two headlight relays in parallel, and some cars have only one relay, but they work the same way.
In theory, this system works just like an electrical circuit with a relay controlling voltage to various other circuits - for instance, a fan control relay turning radiator fans on and off.
Once you understand how this seemingly mysterious system works, it is pretty easy to trouble shoot and fix
