1974 "Battery" gauge
Old Mar 13, 2009 | 03:28 PM
fotyfobravo's Avatar
fotyfobravo
From: Lake Arrowhead - Georgia > 72 Base Coupe & 74 BB Roadster
Default 1974 "Battery" gauge
My 74 has a "BATTERY" gauge. It reads from -40 to 0 to 40+.
What is this gauge telling me.....the current amps from the alternator ...or...the current draw on the battery????
I am starting to think that my alternator is going out, because the "battery" gauge constantly goes from zero to +40 as the engine revs up. It moves from zero to +40 in "concert" with the tachometer.
Help!
Old Mar 13, 2009 | 03:40 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
It's telling you your alternator system is charging your battery, so you want it to at least in the +
Old Mar 13, 2009 | 04:47 PM
justanotherdoe's Avatar
justanotherdoe
Agree with Glass - the function, whether an ammeter or voltmeter, is to tell you if the battery is charging (+) or discharging (-). A strong battery will get to 0 if you drive long enough as it becomes fully charged.
In the winter when its raining, my 76 will actually go (-) at a stop light as I have the headlights, heater blower motor, radio and wipers all running, and only 600 rpm turning on the alternator. It will go (+) when I start moving again and settle at 0 once the momentary discharge is replaced.
Old Mar 13, 2009 | 04:56 PM
Kadorja's Avatar
Kadorja
Same as in my 80. I stop in gear at night with my lights on.. usually in McDonalds drive thru the amazing symphony my sidepipes make off the brick wall.... better then a McChicken any day.... anyways... yeah usually then it drops to around 0.. but usually a little over. Now driving its usually up... not all the way but high enough.
Keeping that in mind when I idle at McD's or wherever I usually drop it in gear with everything in for a minute or so then I'll turn the lights off and let it idle in neutral so I dont drain my battery. Revving it up is also nice
Old Mar 13, 2009 | 05:30 PM
Peterbuilt's Avatar
Peterbuilt
The needle going + or - indicates if electricity is flowing TO or FROM the battery. PG.
Old Mar 16, 2009 | 12:47 AM
mayberg's Avatar
mayberg
Fred - my experience with batteries is this: You usually get a hint, and then they die. If you are getting a hint, act quickly before you get stranded with a dead battery.
If this is your hint, and/or if it's been about 5 years, get a new battery. Even if yours tests out fine.
Old Mar 16, 2009 | 02:05 AM
Kadorja's Avatar
Kadorja
Even a little hint as I dunno a light from an accessory flashing or powering on and off. Or sometimes slow to lug over. In my car the battery gauge doesnt show me how dead the battery is just how much charge its getting. That being said I have to keep an eye out for hints to when my battery is low. Hopefully it wont hint anything for a few more years.
Old Mar 16, 2009 | 08:17 AM
7T1vette's Avatar
7T1vette
Alternator is trying to charge the battery...but it can't. The battery is likely the problem. It may show 12 volts; but it probably drains very quickly.
Old Mar 16, 2009 | 09:22 AM
wombvette's Avatar
wombvette
Help!
Typically it does this after it is started, to recharge the battery. Then after a little while that should settle down to just a slight positive reading when running. If it is not doing this, there is an indication of a problem. Full charging of nearly 40 amps indicated, is not normal, after the battery is recharged and would indicate a regulator problem.
Those of you that have a volt meter, it only tells you that the alternator is charging, and what the voltage is. This does not give you much indication of battery condition, just the condition of charging system. Those with an ammeter can tell a little more about battery condition. A new battery will charge very hard and deep for a longer time to recharge after a discharge. You learn what that charging time and rate is. As the battery ages and its ability to store a charge diminishes, that charge rate and time will get less and less, until the point when you start the car, and there is very little indication of recharge. You will know that the battery is on its last leg. The reserve will be low and the ability to recharge will be low.
To 1974 "Battery" gauge
