Steering column
Old Jan 27, 2002 | 08:24 PM
mike79's Avatar
mike79
Default Steering column
My 79 has aprox. 1 inch of up and down play in my steering column(tilt,telescoping). Anyone know if there is a fix for this?
Old Jan 27, 2002 | 08:42 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Default Re: Steering column (mike79)
Ooh...I'd like to hear this one too...I've got somewhere between 1/2 and 1 inch of play in my '80...
Old Jan 27, 2002 | 08:46 PM
KENTUCKY81's Avatar
KENTUCKY81
Yea I want to hear this one myself. I've got everything tight except for that one item. Looking at a rebuild by empire sterring columns.
Old Jan 27, 2002 | 08:52 PM
DaBo's Avatar
DaBo
Past the turn signal switch, and the steering lock plate are some bolt that need to be tightened. common problem with ALL GM tilt steering columns. Of course the tilt / tele columns are more involved than standard tilt columns.
Old Jan 28, 2002 | 12:01 AM
Chris Fowler
Default Re: Steering column (DaBo)
Any more of a clue as to how to find these bolts? :D
Old Jan 28, 2002 | 12:33 AM
Jim Shea's Avatar
Jim Shea
Go to http://www.corvettefaq.com and look under Suspension and Steering. Go to Tilt & Telescoping Disassembly Instructions; a Column Blow Up Picture; and three pages of sketches on how to disassemble the column.
You can do it with the column still in the car. But it is major surgery to get at the four bolts that hold the column head in place. This is a common problem with the GM tilt and T&T steering columns. The instructions are quite complete.
The standard columns don't seem to have the problem.
JIML82@aol.com
Old Jan 28, 2002 | 01:51 AM
DaBo's Avatar
DaBo
Default Re: Steering column (Jim Shea)
JIML82@aol.com
Exactly, it is a problem with the TILT portion of GM's columns.
I don't understand why they didn't Locktite them at the factory.
Thanks for the web site.....I have an explanation and a breakdown in a Haynes manual but it would not scan so that anyone could read it.
I have repaired the standard tilt columns, but have not done a Tilt/Tele yet.
Old Jan 28, 2002 | 03:20 AM
Chris Fowler
Just took a look through the haynes manual and found the section.
That looks like an amazing pain in the butt to do. :eek:
I've gotta get in there someday and fix the turn signal cutoff too...I guess I'll have to hit both at the same time.
Old Jan 28, 2002 | 03:25 AM
DaBo's Avatar
DaBo
Default Re: Steering column (Chris Fowler '80)
Yeah I know....my 76 only has about 1/4" travel, couldn't imagine much more.
Had an 83 chevy pickup that had so much travel, it would tilt up and down without using the lever.
I have an 80 Vette that I am selling for a friend, and it moves about 1/2"....I was going to fix it until I pulled out the book....guess I will have him deduct a few $$$ from the price.
Old Jan 28, 2002 | 11:40 PM
mike79's Avatar
mike79
Thanks to all for the responce. Looks like Dr. Mike will perform Surgery. I'll post the results.
Old Jan 29, 2002 | 12:27 AM
Jim Shea's Avatar
Jim Shea
DaBo,
If you have repaired a GM tilt column, you know how to do 90% of the work. A T&T column is really just a tilt column with a telescoping upper steering shaft. There is more hardware on the steering wheel but the column is very much the same.
Old Jan 29, 2002 | 01:09 AM
DaBo's Avatar
DaBo
Jim,
I could see that, but the 76 is not that bad yet, and there seems to always be something else to work on. :yesnod: :) :yesnod:
As far as the 80 goes, I am hoping to sell the car for my friend this weekend,
and it decided to get cold here this week. With no heat in the garage, I probably won't do it. If I don't sell it this weekend, and it warms up, I will most likely do it.
If I do, I'll post the results and maybe some pictures.
Thanks,
Old Jan 29, 2002 | 12:47 PM
73 Teach's Pet's Avatar
73 Teach's Pet
I just did this repair with my Brother's guidance in my 87 Trans AM. He suggests tightening the bolts as tight as possible, and using high strength lock tight on the bolts to prevent them loosening again.
Hope the surgery goes well.
Be Cool
"TEACH"
PS . Little Brother has done this common repair sooo many times, that he only charges $20 to do it when he needs a few fast funds!
Old Jan 29, 2002 | 01:14 PM
Jim Shea's Avatar
Jim Shea
Default Re: Steering column (73 Teach's Pet)
As you can tell from the threads, the tilt and T&T head loosening is a fairly common problem.
What really happens with the four bolts that hold the tilt support to the column jacket is this. The support is a die casting. With time the metal under the head of the four bolts begins to yield. The tension in the bolt is then lost and the bolt is now "loose". It then begins to back out and you have more and more play in the connections.
By locktiting the bolts in place, you prevent them from backing out and the connection feeling loose. This problem usually takes years of temperature cycling and years of use to show up. It was never discovered in the laboratory or in the high mileage (but short time duration) GM Proving Ground durability tests. The bolts are now loctited when they are assembled at the manufacturing plant in Saginaw.
To Steering column
