BBC carb height
Old Mar 14, 2009 | 01:50 PM
madmax396's Avatar
madmax396
Default BBC carb height
Have a 71 LS5 corvette all stock. Was wondering if you can put any taller of an intake manifold on there with out hitting the stock big block hood? The motor is out of my car right now or I would just measure. I have the stock Q-jet, edelbrock or Holley carbs I could use in combo with a better than stock cast iron low rise intake.
Old Mar 14, 2009 | 03:26 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
There really isn't any wiggle room under these hoods with big blocks stuffed in there. I have a 68 427/390. I dumped a poor performing Quadrajet for a spread bore Holley and I had to go to a slightly lower profile air cleaner. Stock manifold. I don't think there is any room to go with a performance manifold that is any taller than stock even with the BB hood.
Old Mar 14, 2009 | 04:57 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I measured the clearance in my '71 LS5 and it was 3/8 between the air filter surface and the hood, pretty tight in there!
Old Mar 14, 2009 | 05:31 PM
pats72's Avatar
pats72
When I ditched a stock height aluminium intake for an edelbrock performer on my 72 BB I had to switch hoods. Picked up a small block hood at a swap meet and put a 4 inch cowl on it so I didnt mess up the original hood. In the process of a frame off and plan on going back with L88 style, It is sitting in the garage collecting dust. Would be willing to let it go cheap if you decide to go that route.
Old Mar 14, 2009 | 05:33 PM
Curby's Avatar
Curby
Cruise-In VII Veteran
St. Jude Donor '06
Do what I did, get yourself an L88 hood.
Old Mar 14, 2009 | 05:48 PM
GDaina's Avatar
GDaina
You can always put a drop down air cleaner and base...L-88 style...
madmax396's Avatar
madmax396
I was pretty sure you guys would say there was no extra room, but I had a glimmer of hope. Looking at aftermarket L-88 or Baldwin style hoods.
pats72, you selling the stock big block hood or sm blkk hood with scoop? How much? I'm in salt lake city, so shipping a hood isnt easy.
Old Mar 14, 2009 | 08:09 PM
PeteZO6's Avatar
PeteZO6
You mentioned possibly using a Holley carb instead of your QJet. I measured my 4150 Holley and my QJet from the base of the carb to the air cleaner mounting surface.
Holley 3.475"
QJet 3.228"
No matter what you do, you will have less clearance with a Holley vs. a QJet.
Old Mar 14, 2009 | 11:58 PM
CCrane65's Avatar
CCrane65
You could use the stock 71 LS-6 intake and carburetor if you're looking for a few more horsepower. As I recall the LS-6 made 425.
Old Mar 15, 2009 | 08:08 AM
pats72's Avatar
pats72
Default hood
I am getting rid of the small block hood with the scoop. Sending you a PM with my contact info if you are interested.
To BBC carb height
