I know I have seen posts on this before but now can't find any so here goes, How do I remove the rotors? Do I drill out the spots between the wheel lugs? Thanks in advance, Bubs
Yes, you will have to drill out the rivets if they are still there. Punch the center of each rivet, then drill about 3/8" deep with a 5/16" drill bit. Then enlarge that hole with a 3/8" bit. Eventually, the head will come off of the rivet and you can move to the next. When you've done all five rivets, you may take the rotor off. Don't replace the rivets when putting the rotor back on.
Before you remove your rotors, be aware they weren't riveted on for fun, they were set in place and turned as an Assembly to eliminate run-out, or wobble/high-low spots. Corvette brakes can't tolerate run-out, so if your going to reuse your rotors, mark the position of one of the lug / hole combos. If your installing new rotors they need to be turned on the car ($75 a wheel) with one of those new bolt to hub on the car machines, most large Chevy dealers have them. C.
There are differing opinions out there, but when installing new rotors, you can also shim between the rotor and hub to get the correct runout. I think the max runout you want is between .003 and .005. I shimmed mine on the '76 with good results and others on this forum have too. You can do a search on this to get more info.
It took a good amount of time and some frustration to get the new drilled/slotted rotors on the front of the 68 to .0015 runout. Got brass shim stock in .001, .002, .003 and .005 thickness. Puched them into 1" diameter circles with a 1/2" hole in the center to fit over the lug nut stud. Then tried indexing the rotors 5 different times on each stud and got them to .006 runout with no shims. This is done with 0 play on the wheel bearings. You need to keep track of the runout whether it's inward or outward and them shim accordingly. If only the C3's had floating calipers!
Cheated on the rears, sent the trailing arms to GTR1999 for a rebuild so the new rotors went with them for Gary to dial in.
I bought the shim stock at Ace Hardware and used a Snap-On gasket punch set to cut the circles.
Ace sells a a pack of shim stock in the 4 thicknesses, each sheet is 4" X 6" and there was more than enough for all 4. You'll need to disconnect the half shafts to dial in the rears otherwise you can't turn the rotors easily with the half shafts connected. That's how I found out my trailing arms needed help, the spindle shaft bearings were noisy and had excessive end play.
This started out as a rotor and caliper exchange and look what it blossomed into! Oh well it's a C3 after all.
First, where do I get the shim stock? And when I get that far Gary will probably get mine also.
Also try http://brakealign.com/. Give them a call, tell them you are a private car owner doing some work (not a shop), and you'll find them very helpful. If you know your runout you can order the correct plates you need for each wheel. If not, you can order several correction plates in different sizes. They set me up for $75 for all four wheels.
Measuring and correcting the runout is a little time consuming but very educational and well worth the effort. I did my fronts two years ago and have had perfect brakes since.
I do not believe in the practice of turning brand new HP rotors. Adjusting runout is the only solution IMO.
Mike Ward; I agree it was quite negligent of CM not to address this in their article.
To each his own,, but,, as stated, that's what Chevrolet did at the factory, to evey C3 ever made. My Brakes have also been at 100% since this proceedure 1.5 yers ago.
