Convert tach to electronic
Old Mar 17, 2009 | 11:59 AM
71white's Avatar
71white
Default Convert tach to electronic
Does anyone know of a link or how to convert a mechanical (1971) tach to electronic?
Old Mar 17, 2009 | 12:07 PM
mrvette's Avatar
mrvette
Cheepest/quickest way is to find a good tach from a 75-77 and it's a plug in change...just run the pink wire to any source that's hot when engine is running....a wire to the tach output, through a tach filter.....and of course a ground....
the tach filter is just a network built from Radio shack parts....
no biggie...
Old Mar 17, 2009 | 12:36 PM
zwede's Avatar
zwede
You can move the 71 tach face over to the 75-77 movement. That way you get the original green numerals and red-line.
Old Mar 17, 2009 | 02:10 PM
Gordonm's Avatar
Gordonm
I had mine converted by someone here on the forum. works much better than the cable driven one.
Old Mar 17, 2009 | 02:12 PM
71white's Avatar
71white
no biggie...
Does anyone have a schematic and list of parts for the filter?
Old Mar 17, 2009 | 04:35 PM
71white's Avatar
71white
ttt
Old Mar 17, 2009 | 04:45 PM
Theiskell's Avatar
Theiskell
If you do a search on Tach filter it should pull up any additonal info you need.
Old Mar 17, 2009 | 05:25 PM
71white's Avatar
71white
Thanks!
To Convert tach to electronic
