front clip
Old Mar 16, 2009 | 06:23 PM
glo's Avatar
glo
Default front clip
What bonding glue should I use for reinstalling front clip on a 77.
Whats up with search engine type in front clip came up with everything but and only 8 pages?
Old Mar 16, 2009 | 06:46 PM
Artsvette73's Avatar
Artsvette73
I used fusor made by Lord corp. The application gun is like 65.00
Old Mar 17, 2009 | 06:22 PM
GUSTO14's Avatar
GUSTO14
I would definitely recommend you buy the Fusor Pneumatic 300 mL Dispensing Gun - 304 if you are going to put a front end on. The gun sells for close to $300 as opposed to the manual gun, but it's going to take 5 tubes to put that front end on and unless you're Arnold, your arms aren't going to get it. Some folks say if you heat the Fusor the manual guns will work, but my shop uses the pneumatic and with the pressure they use on the gun, I don't think you're going to like trying the manual gun.
If you use the Fusor 127EZ you can do it with the hand gun, but if you talk to the Fusor rep, they recommend for front ends to use their Fusor T-21 which is much thicker and much stronger and it is almost impossible to do with the hand gun. I recommend you talk to one of the Fusor reps to get the best info, but Fusor is definitely the way to go.
We got the gun through NAPA and they sold it to us for $150 if we bought 5 tubes of Fusor so you might try to see if they'll give you a better price. When you're done, you may be able to sell it to a shop that uses Fusor (most do), many don't have the pneumatic gun and would love to get their hands on one for less than full price.
Good luck... GUSTO
Old Mar 17, 2009 | 06:49 PM
glo's Avatar
glo
Default front clip
thanks I will look into the fuser
Old Mar 17, 2009 | 10:43 PM
temvette72's Avatar
temvette72
I used the 127ez and the manual gun. I used two tubes of the adhesive and had some left over in the second tube. That bonded the front end to the cowl, and the inner fenders to the front clip. A year later and still OK.
Temvette72
Old Mar 18, 2009 | 12:37 PM
57charley's Avatar
57charley
A parts place I talked to said they get guns returned and refund the price if they aren't damaged.
To front clip
