A/C inside fan?
Old Mar 18, 2009 | 07:33 PM
Brown78's Avatar
Brown78
Default A/C inside fan?
My fan inside works. But it only comes out on the floor. I have all the speeds but the gate won't open and send the cold air out the dash vents. Can someone point me in the right direction. I've check all the vacuum lines. I think. Right now I'm . I know it's something simple, and I'm over looking it.
Old Mar 18, 2009 | 07:40 PM
Ganey's Avatar
Ganey
I wrote this up awhile back for this problem.
On at least later C3 the problem is that heater is the default position (no vac. or vac. leak) due to being designed in the north. Vent should be default. Very safe bet the problem is 1 OR 2:
1) The vac. line from engine is damaged from heat - a small plastic tube that goes in below the hood alarm switch into wiper valley. Replacing most of engine side w/ hose will fix. OR
2) The vac. switch itself is not switching due to vac. leak as the usually plastic rivet is not holding the 2 main switch parts together well. Besides replacing, it is also possible to tighten this &/or lube w/ a thin layer of white lithium grease or vasoline to fix.
3) If you have a heater, the small vac. tube to heater hose valve underhood probably also needs replacing. Block w/o heater.
PS The design problem comment is not intended to be offensive to any of our northern friends.
Old Mar 18, 2009 | 07:54 PM
spedaleden's Avatar
spedaleden
with above I would be looking at the vacuum line to the motor. Without vacuum the system won't work. Check for a pinched line also.
Old Mar 18, 2009 | 08:52 PM
Brown78's Avatar
Brown78
Thanks for the heads up. Evey thing is new except for the small plastic vacuum tube. Some how I knew someone would say change the plastic tubes
Old Mar 19, 2009 | 02:22 AM
croaker's Avatar
croaker
They might be melted
Old Mar 19, 2009 | 06:43 PM
Brown78's Avatar
Brown78
Found the leak. a tee coming from the supply to the fire wall that was hidden underneath my MSD box. One of the of the tee bobs was broken off and it looked like a 90* elbow. It's working great. Temp is a cool 45 degrees. Now we'll see when the temp reaches 80* at 2 in the afternoon how cool it is.
To A/C inside fan?
