BB motor horse power
i would suggest the first 20 bucks you spend....buy ed staffel's book " how to build chevy rat motors" for max performance...he has all the factory part numbers and is a great guide on what to do
As said a 2 bolt main Big Block can make 600HP or more with ease on factory parts. So you do not need to spend a great deal of money on one.
And this means a stock cast crank is fine as well. Also the stock 3/8's bolt rods are fine as well. Just use good aftermarket bolts for them. If it makes you feel better you can use studs on the mains instead of the bolts but depending on what power you are after I do not feel they are needed. Even a good set of factory Oval port heads with 2.19in 1.88ex with some bowl work will do great. Then just pick the cam that will work with the intake manifold you are going to use and rear gear and trans and you are set. But to be on the safe side I would say to get forged pistons.
As said you can make 350HP easy. And up to 500HP pretty darn easy as well. Above that things get a bit lumpy lol. Well a lumpy idle due to the cam needed lol.
I wanted to add again that the factory Big Block Oval Port heads with a little work work great. You do not need to use square port heads. And as far as spending a bunch of money on Aluminum heads for performance on the street they are really not needed. Now do not get me wrong they will make the weight lighter over the front end and help with how the car handles and will add about 35HP or so but again are not really needed. The best street head I feel you can get would be the Brodix Race Rite heads as the runners are in the factory location.
Head casting numbers?? Knowing what heads you have is so critical to what will be the best combo for your budget, you'd be making a mistake to start spending money on key components without determining and giving due consideration to this info first. And, even more important, what are your priorities and purposes?
I agree the 2-bolt BB bottom end is fairly stout, but I suggest going ahead and installing the high-quality rod bolts and main cap studs, if there's ever the chance you might decide to add some power goodies (better heads, roller valvetrain, juice...) in the future. Also, 10 lbs per 1000 RPM being all the oil pressure any BB requires, don't waste your money on a HP/HV oil pump; just don't screw up the bearing clearances and an OEM pump in good working order is all you should need. And, if that engine doesn't already have one, plan on buying an appropriate aluminum intake. If you get forged pistons, stay with high silicone 4032 alloy, which permit tighter piston/cylinder clearances.
You may not have the answers, but the good news is that you're asking questions; a sign you're willing to do your homework so you won't have to get lucky to end up with a sound build capable of making some real power. Post up with more info, and there are enough knowledgeable members here (tho figuring out which ones they are isn't always easy) to help you do this right.
TSW
of course that's on a dyno - but i'd like to think that's power enough?!?
RR
