Black Phosphate
Old Mar 19, 2009 | 09:58 AM
71white's Avatar
71white
Default Black Phosphate
Is is possible to do black phosphate at home and is it practical? I didn't see anything at caswell.com.
Old Mar 19, 2009 | 10:33 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
Eastwood makes a kit to do this......I believe it is fairly cheap too.
Old Mar 19, 2009 | 04:16 PM
Alan 71's Avatar
Alan 71
Hi 71,
The process is called 'parkerizing'.
The very dark gray (black) is manganese and the lighter gray is zinc.
It's quite straight forward to do at home.
Check out Palmetto Enterprises for info and supplies.
Regards,
Alan
PS: I believe what Eastwood offers is Zinc Phosphate paint.
Old Mar 19, 2009 | 06:34 PM
redman76's Avatar
redman76
St. Jude Donor '09
Here is the kit Eastwood sells . . . I've been eye-balling that one myself:
Eastwood Metal Blackening Kit
Old Mar 19, 2009 | 09:23 PM
Dave Witman's Avatar
Dave Witman
Tried eastwoods kit and its was ok. the one from caswell works better lasts longer and much cheaper. Dave
http://www.caswellplating.com/kits/black.htm
Old Mar 20, 2009 | 11:12 AM
71white's Avatar
71white
Thanks!
Old Mar 20, 2009 | 04:21 PM
Alan 71's Avatar
Alan 71
I believe the metal backening kit is 'black oxide' which is quite a different coating than 'parkerizing'/ phosphate.
Regards,
Alan
Old Mar 20, 2009 | 06:55 PM
Oldguard 7's Avatar
Oldguard 7
I'm dumb on this one. Is this the process that is used to blacken chrome? I have some black chrome C6 replica wheels and i would like to blacken my door handles to match them.
Old Mar 20, 2009 | 08:22 PM
68AIR's Avatar
68AIR
Black phosphate was a way of preventing corrosion on metal used by GM and others. Black phosphate has a crystaline gray/black appearance on close exam. Black oxide is black and very uniformly dark. There was a person by the name of Grant Wong who was selling the BP solution on ebay which was applied hot to bare metal by using a crock pot or similar to heat the solution. Afterward a coat of wd40 was applied to keep the finish longer. I had a set of male hood locks done for my C3 way back and they came like nos.
Old Mar 21, 2009 | 08:38 AM
Alan 71's Avatar
Alan 71
Hi OG7,
The Black Oxide and Phosphate finishes are for chassis and hardware parts, not the trim finish you're thinking of. Sorry!
Regards,
Alan
To Black Phosphate
