Heater hose on intake?
Old Mar 19, 2009 | 09:07 PM
76projectstingray's Avatar
76projectstingray
Default Heater hose on intake?
I am putting on a new RPM intake and was thinking of not hooking up the heater hose. Should I just plug up the hole in the intake or do you need to run a short piece of hose back to the water pump?
Old Mar 19, 2009 | 09:22 PM
JimT's Avatar
JimT
I've disconnected the heater hoses on several old cars (I lived in Florida) and always ran a short loop-back hose. Don't know if it is critical but it seems like a logical solution - smooth water flow..
Old Mar 19, 2009 | 11:15 PM
71coupe454's Avatar
71coupe454
You never need heat or defrost in NJ? Also I believe some engine heat does dissapate going through heater hose's and heater core.
Old Mar 20, 2009 | 07:17 AM
Ganey's Avatar
Ganey
Yes, you can plug both- mine are. Many just run a loop.
Old Mar 20, 2009 | 07:27 AM
midyearvette's Avatar
midyearvette
plug it.......
Old Mar 20, 2009 | 12:32 PM
BKbroiler's Avatar
BKbroiler
No bypass hose is needed. Plug at the pump and manifold.
Old Mar 20, 2009 | 12:47 PM
SteveG75's Avatar
SteveG75
Stock small blocks have an internal bypass in the block so you can just block it.
Old Mar 21, 2009 | 01:07 AM
Z-man's Avatar
Z-man
I'm sure the heater core dissipates some heat, but if the radiator's working well enough, it will pick up the slack.
Old Mar 21, 2009 | 05:47 AM
Gordonm's Avatar
Gordonm
I live in NJ also and have not had to use the defroster but heat you bet. I have driven on some mornings that are pretty cold. Sure is nice to have a little heat.
BTW yes I agree with others just the plugs are needed. No bypass hose.
Old Mar 21, 2009 | 09:02 AM
76projectstingray
Thanks for the replies, If its too cold to leave the tops off I usually do not drive it!
Old Oct 9, 2011 | 08:08 AM
corvettdreamin's Avatar
corvettdreamin
Whats the best way to plug the outlets, can you buy standard plugs somewhere, pics...
Old Oct 9, 2011 | 08:59 AM
Paul L's Avatar
Paul L
Brass plugs (with NPT threads) at your local plumbing store.
Old Oct 9, 2011 | 11:20 AM
7T1vette's Avatar
7T1vette
If the heater core is damaged or plugged, you can just block off the outlets. If you just don't like the way that hose is routed over the A/C compressor (don't know if that's the reason for your question, or not), just reroute that hose under the compressor. If you do that, you can also put a lever-type water shut-off valve in that line [below the compressor] and it will hardly be noticible.
To Heater hose on intake?
