on a Gen 1 block. I hear it's a bolt-on with no issues other than a different intake. Will my headers work too?
With my setup I'm just short of 10:1 using cast iron heads with (I think) 72cc chambers. How much will the smaller chambers in the Vortecs raise my compression ratio and will it have more of a tendency to ping?
Right now it pings a slight bit when good & hot or with the AC on. Most driving can be done without it pinging but it does happen now & again. I don't want to go with another cast iron head with smaller chambers, if its going to ping more than it does now.
The odds are not in your favor. The Vortecs are a 58cc head (I believe) and that'll bump compression quite a bit.
They probably are designed better and are less likely to detonate at the same CR than a stock head, but I'd avoid it.
IMO, you'd be better off saving your cash a little longer and getting an aluminum head in the 68cc range. You'd have better cooling, better heads, and a lighter engine.
Thanks Sharkman that's what I'm thinkin' too. I just did more reading onthem and it seems the factory springs in them are only good for about a max lift of .420" without changing. And to change the springs requires machining the head because the center post on these is designed to locate the spring. In order to change out the spring you have to machine post on each one.
My cam is mild but I just pulled the Crane spec sheet out and iit shows .454/480 lift at 1.5 so you need to add a bit more to that for 1.6 rockers too.
So by the time I got different springs on the vortecs (and oh, you need to machine the pushrod hole too if using 1.6) and paid for machine work I would be into them as much as if I bought aluminum heads. And I'd still have the propensity for ping ....
So that leads me to the aluminum head Q: Best bang for the buck? I can get Edlebrock heads right here locally for $599 each complete. No shipping no nada just cash & carry. I'll need a new intake too because the Performer intake that's been used on the stroker was milled to match the mill they took off the heads. And it was also port matched to those iron heads.
Maybe a Performer kit with heads & intake? Sans camshaft?
Vortecs are 62cc's (advertised as 64). If you ping with 72's, you'll rattle with 64's. I've run 'em with flat tops at 10.1:1 on computer controlled engines, but I don't know that I'd push it with no knock detectors, etc., and you'll probably be close to 11:1 with Vortecs. If you're running dome pistons, they probably won't work with the Vortec heart-shaped chambers, either.
No they are flat top (forged) pistons but still, I guess the Vortec scene just ain't happening. I wanted to get something that was inexpensive & would run better than it did with the setup I've had together for 5 years.
Since I'm convinced my bottom end is OK then I'm going to choose heads wisely and try to recover the power missing from the original setup. I wanted to get a minimum of 300+HP at the wheels when I built the motor and fell a bit shy of that using these heads.
As others said since one spring broke, no reason to trust the rest of them. I need to yank off that other head and never look back.
Who sells a matched combo of aluminum heads & intake? Besides Edelbrock?
I think the best bang for the buck is the edlebrocks if you can get them for $599. That is a great price. Good possibility you can reuse your intake too. Bet the port match is real close to the edlebrocks and there is a thicker intake gasket available.
Thanks Mako that's good news. How to tell if the thicker gasket is needed? Set the heads on the motor & then set the intake on it without a gasket//check for gaps?
Yes, Check with a feeler guage after bolting the heads down. There are a variety of thickness intake gaskets available. Is the 599 price each or for a pair? If it is for a pair, assembled buy them today or they will be gone tomorrow. If it is each there are better options. Brodix IK 180 comes to mind. AFR 180 streets will definetly get you 400 FWHP with your setup.but they are a little more money. You get what you pay for with heads. Whatever you do stick with a name brand head. Don't go for the $600 assembled chinese e-bay heads. http://www.jegs.com/i/Brodix/158/1021004/10002/-1
Yea I was just looking at choices - they are a dime a dozen No way I'm buying no-name stuff.
the price quoted at 599.00 was EACH for complete heads, angle plug or straight. Don't know which I want.
I've done work on angle plug engines before but I dont' remember if the plugs were easier to remove with headers or not. If I can make them easier to remove & also get the bennies of the angle plug then that's what I need to do. Assuming my old headers will work.
Those Brodix heads will save you $150 with shipping and flow better than the edelbrocks.
