Cas.... You are attempting install lower bushing on the upper A-frame or vise versa. You should have four short and four long bushings in your rebuild kit
I asked this question on several other fora. ES did confirm this. It turned out this is not an issue as long as there is enough thread for the bolt. The car is not finished so no road test jet.
