COMP Cams ???
Old Mar 21, 2009 | 12:42 PM
PuddleJumper's Avatar
PuddleJumper
Default COMP Cams ???
hay guys
got an few questions about COMP Cams
how good are there solid and hydraulic flat tappet lifters, Cams, Rocker Arms, and Push rods?
i have herd bad things about them and im not to sure about them anymore.
is there some one out there who has better cams but that are not an arm and an leg to get?
Ryan
Old Mar 21, 2009 | 01:09 PM
Billysvette's Avatar
Billysvette
Go with a hydraulic roller cam,dont have to worry about the low level of zinc in oil,that will wipe out your cam lobes.
Old Mar 21, 2009 | 01:24 PM
jbowles49's Avatar
jbowles49
Comp is a highly reputable firm and I have had no problem with their products though I am currently using a Schneider product. That said, your satisfaction with any cam selection is only as good as your ability to
select the appropriate cam for the engine you have not the one you wish you had. Good luck
Old Mar 21, 2009 | 02:06 PM
Gordonm's Avatar
Gordonm
I have run a variety of solid flat tappet cams from Comp. I have always used their lifters. If you follow the proper break in and use the proper oil it should be no problem. I have had good luck in the last 15 years with their products.
Old Mar 21, 2009 | 02:28 PM
PuddleJumper
yah im using Dyno2003 and COMP Cam quest to help me find the best cam. i have 2 engine builds in mind an 350 (4.000x3.484) and an 377 (4.000x3.750) the 377 is just like the 383 except the 383 has an .03 over bore.
i was asking being i have herd people saying they hate COMP cams
they seem to look like an ok company. thanks for you input guys.
Ryan
Old Mar 21, 2009 | 02:48 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I just had the flat tappet vs roller conversation with my engine builder this morning. I have the old style block so to go roller it require those retro-roller lifters so I'm looking at a price diff of ~$500.00. My budget is tight. We got on the conversation of oil and break in etc. He told none of the production oils have enough sulfer or zinc an more, not even Rotella. He told me that regular use of STP Oil treatment is how he solves the issue. This guy has a long term local rep for knowing what he is doing so I plan to go with the flat tappet and follow his advice. He is recommending a crane cam and lifter kit and I gave me the go ahead this morning. I kinda get 's about the STP thing but he swears by it....so i guess we will see.
ps; Apologies if I hijacked the thread. I really don't have a comment on the Comp stuff as I have no experience with it.
Old Mar 21, 2009 | 03:15 PM
PuddleJumper
actually i was just thinking about that i think im going to have to go to flat tappet being the blocks im looking at are from the 1970s early 80s im 98% sure non of them are roller lifter capable.
yah i don't want to have an wiped lobe on this thing being my budget is very small.
http://www.cranecams.com/pdf/548e.pdf (intresting info i found on Crane Cams web sight oh is COMPETITION CAMS and COMP CAMS one and the same ???? i know its a stupid question but i don't know
Ryan
Old Mar 21, 2009 | 03:28 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Nothing but good luck with Comp Cams in the past. Right now I'm running a Comp Cam Pro Magnum 1.6.1 roller rockers set up.
Old Mar 21, 2009 | 03:57 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Ryan, just a heads up because I remember from your other threads you don't have a block yet. It would be wise to get an '87 and newer block if you're going to go roller.
I personally am going with a retrofitted roller cam just because of the ease of mind. Last thing I want to worry about is a wiped lobe.
Old Mar 21, 2009 | 04:18 PM
PuddleJumper
the 4 87 or newer blocks he has are "running" engines ie around $500-800 not realy what im looking for
Old Mar 21, 2009 | 04:23 PM
speedreed8's Avatar
speedreed8
i saw in the news last week Crane Cams, went out of business. i saw on jegs website under cams. delivery date for crane cam was unavailable?? also heard they filed for bankruptcy and were reorganizing to reopen.??
Old Mar 21, 2009 | 04:43 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
My car was treated with a comp cams camshaft back in 1990, and when I took my engine apart few months ago, I was amazed how the camshaft was in such a great condition! .. I expected at least one wiped lobe, but it turned out to be in great shape.
Old Mar 21, 2009 | 05:24 PM
PuddleJumper
i think you may be correct because i was looking for prices at Crane and all i got was nothing no prices on anything no buy now thing nothing. from the sounds of it im just going to go with COMP because of the ease of selecting and finding a cam.
Ryan
Old Mar 21, 2009 | 08:11 PM
l88rocket's Avatar
l88rocket
I have run Comp Cams componets in everything from stock 350's to 706 drag engine. And have had very little problems with there parts. IMO Comp is the best you can buy.
I believe I read somewhere Comp grinds all the ZO6 and ZR1 cams for gm.
Old Mar 21, 2009 | 10:02 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
If I was going Flat tappet I would probably use Crower. They are a high quality product. My hydraulicr oller, lifters, rockers and timing set are all Comp. Good company. Only problem I ever had with them was a set of lifters that had a couple that wouldn't stay pumped up. Had been sitting waiting for a build for almost 3 years. They accepted a return and replaced them with no problem.
Old Mar 21, 2009 | 11:38 PM
VictoriaVette's Avatar
VictoriaVette
I have comp cam, lifters and springs and would use them again this is my second time using them.
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Past and future CompCams repeat customer here.
To COMP Cams ???
Old Mar 22, 2009 | 01:07 PM
69vettester's Avatar
69vettester
My 383 Build top end was 200cc Brodix, and Full roller Comp. assembly. Rockers are Pro magnum's.
IMO the comp haters had a failed Top build , trying for too much power using a flat tappet cam and lifters. No or low zinc oil during breakin. Recipe for disaster in the past 4-6 yrs.
This is roller assembly years, Or risk wasting time and Money.
Old Mar 22, 2009 | 03:29 PM
Billysvette
down the road you might forget to put zinc additive in or wrong oil and bam its too late wiped cam lobe,go roller ,if you dont have money ,wait till you do I am tired of flat tapped cams and the worry.Oh and comp cams ,they are a good product ,never any problems with them.
Old Mar 22, 2009 | 03:48 PM
PuddleJumper
yah idk i will see when i get there i guess. i know roler would be better but at 5 times it might not be worth it for this rebuild being what purpose it has if i work out an deal with my Best Friend Donna's Dad i will put roller in it for sure
