rear toe align
Old Mar 21, 2009 | 06:52 PM
ace71x's Avatar
ace71x
Default rear toe align
toe is out on one side in the rear of my car,can't add shims ,and can't get the bolt out either to switch the orig shims around..
Old Mar 21, 2009 | 07:02 PM
temvette72's Avatar
temvette72
If your Vette is a 69 or later, the shims have slots, so you don't have to completely remove the bolts to add/subtract shims. There is a big cotter pin that secures the shims to the frame pocket, just below where the trailing arm sits. If everything is corroded together, you may have no choice but to sawzall through the bolt to remove all the rusted hardware. Many posts on this forum sing the blues over this process. When I did my T-arms, I resorted to a sawzall. I replaced all the hardware (bolts, nuts, washers, spacers, and cotter pin) with stainless steel pieces and lotsa anti-seize. Good Luck!
Temvette72
Old Mar 21, 2009 | 07:21 PM
Emeightch's Avatar
Emeightch
Ah yes... So we meet again Mr. Trailing Arm Bolts.
P.S. Don't forget to buy ALOT of extra blades!
Old Mar 21, 2009 | 11:21 PM
TOM B1's Avatar
TOM B1
Can someone post a pic of where this cotter key goes, I cant find a hole in my 69 frame for it.
Old Mar 22, 2009 | 09:19 AM
ace71x's Avatar
ace71x
I have a 69 coupe. It seems as if the bolt goes right through the shims,like the older style. The shims move freeley up and down, but you cant pull them out without pulling the bolt out ,and the bolt is frozen. I took out the cotter pin and the nut and tried to knock the bolt out ,but no good?
Old Mar 22, 2009 | 01:02 PM
temvette72's Avatar
temvette72
My bolts and shim packs were rusted into a solid mass of....whatever you call it. That bolt was really stubborn. After I cut through it on both sides of the trailing arms, I had to pound on the little stubs that were left in the frame really hard to get them to pop loose. It doesn't help that you have to hit them on a funny angle with a drift. Also, the little piece that was left in the trailing arm took a drift and a 5# sledge to break loose. If yours are that bad, I can't see being able to get enough force on that bolt to remove it intact. The good news is that the new-style shims are really easy to put in and it makes it easier (though not a piece of cake) to thread the new bolt through the frame and the trailing arm.
Temvette72
Old Mar 22, 2009 | 01:14 PM
temvette72's Avatar
temvette72
Here is a pic I just took. Sorry for the quality. I put a dab of red paint on the cotter key to highlight it. Temvette72
To rear toe align
