1980 4/speed "grinds" into reverse...need help
Old Mar 21, 2009 | 07:39 PM
demoke's Avatar
demoke
Default 1980 4/speed "grinds" into reverse...need help
Just had my original L-48/190hp rebuilt to a 355 hp and also replaced the worn-out clutch . The engine was built with 10.25 to 1 Speed Pro Hypereutectic Pistons, a Comp Cams .500 lift Hydraulic Roller Camshaft, Professional Products Typhoon Intake and a 750 CFM Holley Carb. The clutch was replaced with a Ram clutch. My problem is that my car(a 4/speed) is very difficult to get into reverse without "grinding" the gears. In the am when i start the car, it will go into reverse easily, but as the car warms up, it becomes more difficult. Any suggestions as to what this might be. i've tried tapping the gas pedal to get the rpm back down but doesn't really help. It also did this before the rebuild but not this bad. Any help would be appreciated. I did not do the rebuild myself and am only a "novice" mechanic at best....thx again
Robert
Old Mar 21, 2009 | 07:44 PM
Gordonm's Avatar
Gordonm
I would suspect the clutch is not adjusted correctly. Reverse gear does not have a syncro so the gears should be totally stopped before trying to shift into reverse. If the clutch is dragging slightly the gears may still be turning therefore grinding a little going into gear. Try to adjust the clutch first.
Old Mar 21, 2009 | 08:02 PM
TimAT's Avatar
TimAT
Sometimes the pilot bearing will be a little rough and is keeping the input shaft turning even with the clutch adjusted properly. Just shift it into first gear and then go to reverse.
Old Mar 21, 2009 | 08:55 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Works every time!!!
Old Mar 21, 2009 | 09:59 PM
71coupe454's Avatar
71coupe454
put it in reverse before you start it?
Old Mar 21, 2009 | 11:31 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
that's what I do, too.
Old Mar 22, 2009 | 06:31 AM
7T1vette's Avatar
7T1vette
Those 'tricks' will abate the problem...but the cause may still be that the clutch isn't fully disengaging when you apply it.
Old Mar 23, 2009 | 09:51 PM
demoke's Avatar
demoke
Thx everyone...i can go into 1st gear, then reverse...that works great! i will do this until i can get my clutch adjusted...thx so much for all the help...Robert
To 1980 4/speed "grinds" into reverse...need help
