1970 LS5 TCS Photo request
Old Mar 22, 2009 | 04:38 PM
wer2xu's Avatar
wer2xu
Default 1970 LS5 TCS Photo request
I was hoping someone could post a few pictures of the original TCS system on there LS5, I want to see the proper method for plumbing the wiring, and I am not sure exactly where the temperature sender is mounted.
Thanks for the help!
Old Mar 22, 2009 | 10:20 PM
71coupe454's Avatar
71coupe454
I think the only thing left on mine is the temp sender... r/s head, 2 wire I think.. 71BB though..
Old Mar 22, 2009 | 11:01 PM
CCrane65's Avatar
CCrane65
The temp sensor is the same for all LS5's. It is a 2 post in the right head. There is a green pigtail wire with the two post connector on one end and a single post connector on the other. It plugs into a harness connector behind the right valve cover with a blue wire.
There should be a TCS two post flat connector near the distributor that plugs into the TCS solenoid which is mounted on an intake manifold bolt on the passenger side.
Finally, there is a single black wire that plugs into a switch on the bottom of the 3-4 shift lever housing on the transmission. It provides a ground to the TCS system when the car is shifted into 4th gear.
Sorry I don't have any pictures of a 1970 TCS set up but here is a picture of the temperature sensor and the wire pigtail so I hope this helps.
cc
Sensor:
Pigtail:
Old Mar 23, 2009 | 08:54 AM
71coupe454's Avatar
71coupe454
Is this part of the system needed or important? any downside to it being missing/inop? I have 2 small relays? on the firewall just next to the b/booster box/emission sticker. are they part of it? thanks
Old Mar 23, 2009 | 10:02 AM
CCrane65's Avatar
CCrane65
I know one of them is part of the system. Don't know about the other one.
They are part of the emission control system. They really didn't do anything to reduce emissions but it was all the technology that was available at the time.
The TCS system blocks vacuum advance until the transmission is in 4th gear for manual transmissions and final drive gear for automatics. The relay comes into play when the car is first started and provides a 20-30 second delay in TCS activation to allow the temperature sensor to provide feedback on whether the engine is below 80 degrees (advance allowed) or above 220 degrees (advance allowed) then advance is blocked until the transmission is in high gear.
cc
Old Mar 23, 2009 | 10:18 AM
dennis's Avatar
dennis
here,s a schematic of the sytem components that might help you
Old Mar 23, 2009 | 10:51 AM
7T1vette's Avatar
7T1vette
The whole purpose of the TCS system was to shut down the dist. vacuum advance until your tranny was in the higher gear ranges. So, at the expense of engine performance, fuel economy, and engine life you could hook it all back up. Or, you could wire/plumb it all per factory...but swap a couple of hoses so that the vacuum advance is always working, then swap it back for emissions testing and/or car show. [That's what I've done on my '71 SB].
Old Mar 23, 2009 | 03:07 PM
CCrane65's Avatar
CCrane65
To be perfectly honest 7T1vette, I hooked mine all up and haven't noticed a drop in performance or fuel economy (how would you tell fuel economy dropped on a big block anyway?) and I really would be surprised that engine life would be adversely affected by this setup since it had to be supported by the factory.
cc
Old Mar 23, 2009 | 03:24 PM
7T1vette's Avatar
7T1vette
Anytime you inhibit the vacuum advance from working [at idle, particularly], the engine will run hotter, which will impact engine life. That's the intent, actually, since a warmer engine will burn off more 'excess' hydrocarbons. {That's also why vehicles have 195F thermostats now.} If yours hasn't been impacted, then I suspect that the system just is not operational...even though it is "hooked up". You can determine whether it is working or not by checking your ignition timing and seeing if it is advancing [or not] at idle. P.S. I was merely attempting to provide you with some background on the system for the original poster.
Old Mar 23, 2009 | 06:21 PM
wer2xu's Avatar
wer2xu
Thanks for the help guys...when the engine was replace in my car the PO did not bother installing this particular system. I have the connectors tucked away by my washer bottle hose. My intent was to put all of the pieces of the system in place, and like 7T1 said, bypass the vacuum solenoid for driving, and at a show plug it in.
I just wanted pictures of an engine bay with everything hooked up to make sure I get things where they belong, routing of harness, and hoses, etc....I could probably get it in the AIM, but a real picture would be very helpful.
Old Mar 23, 2009 | 08:46 PM
CCrane65's Avatar
CCrane65
Trust me, it's operational. After the engine reaches 80 degrees it idles down to 850 rpm which is . And if i disconnect the TCS completely the idle drops even more. When I come to a stop the TCS drops the idle speed to 850.
Now these may not be what the system is supposed to do but it is definitely functioning.
cc
Old Mar 23, 2009 | 09:46 PM
70454Convert's Avatar
70454Convert
Here you go. TCS on 70 454. I'd be happy to post a more birds eye view of the system but unfortunately it's all disassembled while I repaint my intake. I hope to have it back together in the next 2 weeks. If you still need the pics, PM me and I'll post when all is assembled.
To 1970 LS5 TCS Photo request
