Testing Replacement Electronic Tach
Old Mar 23, 2009 | 11:06 AM
wjsullivan's Avatar
wjsullivan
Default Testing Replacement Electronic Tach
The tach in my '75 functions like the 'big wheel' on wheel of foturne, it goes all the way around and then does nothing when I start the car. So I figure the board is fried. I picked up a used one from a rollover (thanks vettes by design) that is supposed to be working but really don't want to put my whole dash and steering column back in only to find out the new one is dead also. I am also reading that a new board would have to be calibrated once installed, so it really appears I need to rig this up with the column (or at least ignition) and get it set.
So here is what I am thinking:
1 - Pull the 'new' used tach from its bezel and plug it in, without the dash pad.
2 - Lay the column back in the car on the floor and reconnect the electronics
3 - Reconnect the battery
4 - Start the car and check that the tach reads and reacts to the gas peddle.
5 - Turn the key to the on position (engine off) - check for 0 reading - adjust per standard 'calibration instructions' (pull needle and rest to proper position, etc.)
Any other method of bench testing or otherwise testing this?
Old Mar 23, 2009 | 11:18 AM
QuicheLorraine's Avatar
QuicheLorraine
When I did my dash a few yrs ago, I made the mistake of taking the '76 tach to the local Speedo-Tach shop to have 'em verify the tach since it had never worked. I think he messed with the pots in the circuit board because it's got crazy readings even with a new tach filter installed. I wish I had found a way to check it myself because it's a lotta work to get it out, and I wasted all that time. Now I'm tempted to just buy a Sun tach and strap it on to the column.
Old Mar 23, 2009 | 08:54 PM
markdtn's Avatar
markdtn
You could do that, but you can check it out of the car. Pink is ignition switched, Brown is tach (AFTER the filter), Black is ground. Hook it up with alagator clips in the engine compartment after the filter and it should work.
Old Mar 23, 2009 | 09:29 PM
tfi racing's Avatar
tfi racing
Can it be tested without the filter?I have a tach I would like to sell or trade but I would like to know if it is working or not before I list it here.
Old Mar 23, 2009 | 11:00 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Instead of doing this in the car, you might consider doing it by the engine. I’ll explain why below.
To do this, just run 12 volts to the tach, a ground and then loop in at the distributor cap connection (marked Tach) for your signal.
The signal to the tach is a square wave signal which can be split over and over. So, get an old fashion Actron dwell/tach/volt meter and you can test away. On the upper corner of the board is an adjustable pot. You can use this to dial in the readings.
If you go to our site, we have a picture of the board with the inputs labeled so you should not have any problem with this.
As mentioned above, the tach filter is not needed for testing and you can get 12 volts off the back of the alternator, a ground off the engine.
If you do it this way, you will eliminate any variables in the wiring. Now just to be sure once you have the new board in place and tested and before you put it back in the car, plug it up on the inside. If your tach has problems on the inside and not on the outside, you have a wire issue.
If you don't have any luck, send it to me and I'll dail it in on our machine.
Willcox Inc.
Old Mar 25, 2009 | 02:51 PM
tfi racing's Avatar
tfi racing
Thanks,I'll give it a try.
Old Mar 26, 2009 | 03:51 AM
hunt4cleanair's Avatar
hunt4cleanair
Sullivan,
You've got the right idea by bench testing especially on those 75-77s with dash issues and Wilcox offers some great suggestions.
I might add that Wilcox was a great help to another CVer who had problems with his 76. Owner sent tach and board to Wilcox who than troubleshot and returned in order.
Illustrates great service for this type thing.
Old Mar 26, 2009 | 08:31 AM
wjsullivan's Avatar
wjsullivan
After much back and forth I broke down and laid the column back on the floor and plugged in the tach as you normally would. Got everything calibrated and up and running.
Then the fun part, putting the dash and steering column back in.
To Testing Replacement Electronic Tach
