700r4
Old Mar 24, 2009 | 06:41 PM
PEPresnell's Avatar
PEPresnell
Default 700r4
I have a 700R4 trans I would like to put in my 74, have any of you done this? I have read a lot about replacing a 350 but nothing on changing out a 400. Do you have to cut out the crossmember for clearance? Will the 700 mounting bolts fit or does the mount have to be moved back?
Old Mar 24, 2009 | 06:47 PM
'75's Avatar
'75
This may help.
Old Mar 24, 2009 | 06:59 PM
PuddleJumper's Avatar
PuddleJumper
Originally Posted by Aktbird
This may help.
do you have an larger version of this picture
Old Mar 24, 2009 | 07:42 PM
'75's Avatar
'75
Blew it up a bit
Old Mar 24, 2009 | 07:45 PM
PuddleJumper
No, thats the only size
Old Mar 24, 2009 | 11:54 PM
LACLANCHE's Avatar
LACLANCHE
6th Gear
you need to get the out put extension with the hole for the transmission mount it should fit right with the hole in the cross member where the 400 is bolt
To 700r4
