radiator....bleeding???? help
Old Mar 24, 2009 | 06:46 PM
78vette78's Avatar
78vette78
Default radiator....bleeding???? help
my upper radiator hose has a hole in it. So im about to replace it but somobdy told me that i need to bleed it when i put the new coolant/antifreeze. But i dont know now to do that......... help please
thanks in advance
Old Mar 24, 2009 | 07:18 PM
1nicecorvette's Avatar
1nicecorvette
not that im aware. first dont start the car. get a small can or bucket to catch what is left in the hose. take and loosen the clamp at the stat first. pull the hose and hold it in the air higher then the top of the radiator. although there should only be drips of coolant in there ya never know.put the new hose on the stat part. get ready for there might be some spillage here. take loosen the radiator part of the hose ..pull it and get the other end slipped on in a hurry if you do encounter some leakage. its all pretty much a straight forward deal. pretty much one of those "fun" easy projects to do. no need to drain the system unless the coolant isnt protecting anymore or is contaminated. good luck!
Old Mar 24, 2009 | 07:24 PM
BassCat's Avatar
BassCat
Yep, pull the old one off, slip the new one on.
Old Mar 25, 2009 | 12:14 AM
Z-man's Avatar
Z-man
...then, after you drive it for the first few times, keep your eye on the coolant level. It usually goes down as the air bubbles are flushed out of the block, and you need to add coolant.
Old Mar 25, 2009 | 05:43 AM
78vette78's Avatar
78vette78
cool..... thanks guys...... i was kinda sad that that happened today since it was a nice day and i wanted to drive my vette.
but its ok it looks like that needed to be flush and put new coolant anyways. it looked dirty when it spilled a little bit from the leak so its something that it need to be done.
Old Mar 25, 2009 | 05:46 AM
78vette78's Avatar
78vette78
ohhhhh..... do u guys know hot to drain it all the way???
Old Mar 25, 2009 | 10:23 AM
bashcraft's Avatar
bashcraft
There is a petcock on the bottom of the radiator and a pipe plug on each side of the engine block.
Old Mar 25, 2009 | 10:29 AM
08vycpe's Avatar
08vycpe
If you drain your system you will need to burp the air out. I find the easiest way to do that is to park the car on an incline so the rad fill is the highest point. Then with the rad cap off let the car idle at temp for a few minutes.
Old Mar 25, 2009 | 07:15 PM
Jack Wood's Avatar
Jack Wood
Default Yep, raise the front end to burp with the radiator cap off.
Replace the radiator cap when the thermostat opens and the water starts to flow. Clean up/empty old coolant - pets lap it up then die.
Old Mar 25, 2009 | 07:26 PM
thegazman's Avatar
thegazman
Default thrgazman
When you refill your radiator with antifreeze pull the heater hose off of your intake manifold and fill until water comes out of the manifold connection. That way you are assured that all the air is out of your water pump and engine.
Old Mar 26, 2009 | 03:16 AM
78vette78's Avatar
78vette78
im jus wondering what will happen if there is air inside???
Old Mar 26, 2009 | 07:08 AM
JimT's Avatar
JimT
You can eliminate the need to bleed radiators by using a thermostat that has bypass holes. EMP/Stewart (sold by Summitt) works very well. Should the thermostat every fail, the bypass holes allow water/fluid flow. You can also drill your own holes, 2 each 3/16" in your current thermostat. These also work great for allowing air to pass through the system while refilling fluid.
To radiator....bleeding???? help
