Rear Wheel Play
Old Mar 24, 2009 | 06:54 PM
VictoriaVette's Avatar
VictoriaVette
Default Rear Wheel Play
Well here is my question I just finished installing new strut rods on my 77 and a friend o mine want me to help him install some adjustable strut rods. So I did and after we were done I noticed that there is some play in the rear tires. If I grab the tire at 3 o clock and 9 o clock everything it nice a tight no play at all. But when I grab the tire at 12 o clock and 6 o clock I can move the tire back and forth about 1/16" of an inch on both wheels. So is this normal? I did not check mine after I was done but I will.
Old Mar 24, 2009 | 08:09 PM
GTR1999's Avatar
GTR1999
Diff yokes
Old Mar 24, 2009 | 08:41 PM
VictoriaVette
I checked the yokes not there and the struts are good and tight. No side to side play just top to bottom play. I push the top of the tie and pull the bottom.
Old Mar 24, 2009 | 08:49 PM
VictoriaVette
I went back and looked again it looks like it is moving where the half shaft bolts to the back of the bearing assembly. The assembly has play it self. But I was told that if it was not 3 to 9 play it was not the bearings. I guess this is not true? Both sides have the same movement they have never been apart and it has only 61000 miles.
To Rear Wheel Play
