Steering Column Removal
Old Mar 24, 2009 | 09:27 PM
shashi27's Avatar
shashi27
Default Steering Column Removal
How would you guys rate the difficulty of swapping out the standard column in a 70 with a tilt/tele? I bought a compatible column but is it as easy as removing the two support bolts holding the column up, the wiring harness connections, and the two firewall bolts? I don't have a rag joint because I have a Steeroids rack.
Thanks for your feedback.
Old Mar 24, 2009 | 10:30 PM
72LS1Vette's Avatar
72LS1Vette
That's pretty much it. Not a difficult job if you are sure the new column will just drop in. I put a 79 column into a 72 and I had to trim the housing a couple of inches and remove/reinstall the wiring into the 72 connector so it would plug into the harness.
Rick B.
Old Mar 24, 2009 | 10:47 PM
Jim Shea's Avatar
Jim Shea
This paper has very complete instructions on dropping and removing the steering column.
http://jimshea.corvettefaq.com/wp-co...ev21mr2009.pdf
Jim
Old Mar 24, 2009 | 11:00 PM
Buzzardz_vette's Avatar
Buzzardz_vette
Rick B.
I'm glad to hear that as I'm replacing the column on the 75 with a T/T from a 76 and also installing a Steeroids. I've heard that the bearing at the end of the column should be changed at the same time. Is this true?
Old Mar 25, 2009 | 09:17 PM
shashi27's Avatar
shashi27
Thanks, guys. This info is great. I feel much better now about doing this myself.
Old Mar 26, 2009 | 09:56 AM
Buzzardz_vette
Jim
Thanks for the link. Looks like it covers just about everything you need to know about steering.
Old Mar 26, 2009 | 10:55 AM
Jim Shea's Avatar
Jim Shea
I am always open to comments, suggestion, etc that would make the papers more understandable. As you can appreciate, I obviously haven't taken a steering column out of every model year of C3 Corvette. So particularly if you find things that are different it helps to update me so I can revise the paper(s).
Good luck,
Jim
Old Mar 26, 2009 | 11:08 AM
dobroman2001's Avatar
dobroman2001
Here's some Pics of my '76.... followed Jim's paper. Right on the money!
http://s189.photobucket.com/albums/z...man2001_photo/
To Steering Column Removal
