I'm trying to hook up my vacuum accessories to my new carb and I see a few other threads that are trying to do the same thing.
My new carb only has one 3/8" vacuum port on the back for power brakes. On Lar's paper on how to set up a demon carb, he uses a " T " fitting to run the power brakes and PVC to the back of the carb. I was going to do this ,then someone told me I could cause a problem with the brakes having the pvc on the same line as the brake booster. Has anyone set up their vacuum lines this way?? and did it cause any issues with the brakes?
I know, a lot of people do, but personally, I wouldn't hook it up that way. A PCV valve is essentially a constant, though restricted vacuum leak. It could, depending on how it's plumbed and what fittings are used, decrease the vacuum signal to the booster. Also, PCV valves do occasionally fail. That's why you can go just about anywhere and buy one. In the event of a failure, the vacuum signal could be greatly reduced.
I suppose there's also the possibility of engine oil entering the booster. Not sure what effect this may have.
i respect fully your opinion, but it is totally incorrect...........a faulty pcv would have the same effect on the vacuum signal no matter where it is hooked up to a direct manifold port, albeit the manifold fittings or the carb base....truth....
That's true if you're talking about the vacuum signal inside the manifold. The problem is you now have 2 systems using vacuum through 1 port which was designed to supply vacuum to only 1 system. A tee causes an even bigger restriction. Why do you think GM never did this?
gm had the luxury of drilling as many ports in the manifold as they cared to, mainly to avoid tees and all the plumbing. i will admit, it would be nice to have a manifold port where ever one wanted, however this is not the case for the poster. since the source is a plenum and the manifold, it really does not matter how many ports are used, if one port has a leak, then it will effect other ports in exactly the same way..... i think you are confusing vacuum with presure?....
How much vauum does the PVC need? My new drop base air cleaner has a fitting that you can put on the bottom for a 3/8" hose. Can the PVC be hooked up to the bottom of the air cleaner? My original air cleaner had the fitting on the air cleaner going to the valve cover for the breather.
The PCV needs manifold vacuum. The hose to the air cleaner base goes to the breather on the other valve cover. It supplies filtered air to the crankcase.
